Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2014-11-26T20:12:23-04:00 http://buildyourownsla.com/forum/feed.php?f=11&t=2176 2014-11-26T20:12:23-04:00 2014-11-26T20:12:23-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2176&p=6331#p6331 <![CDATA[Re: Casting directly in the 3D printed mould]]> Statistics: Posted by PomeroyB — Wed Nov 26, 2014 8:12 pm
2014-11-26T16:04:37-04:00 2014-11-26T16:04:37-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2176&p=6324#p6324 <![CDATA[Re: Casting directly in the 3D printed mould]]> I create my pewter molds using smooth-on's moldmax 30 silicone rubber. You can cast multiple times with minimal detail loss. And if you create a support shell using plaster of Paris, the cost of the mold is greatly reduced.
This way you preserve your printed model and can make as many molds as you want.
Statistics: Posted by seasicksinbad — Wed Nov 26, 2014 4:04 pm
2014-11-25T14:07:36-04:00 2014-11-25T14:07:36-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2176&p=6304#p6304 <![CDATA[Casting directly in the 3D printed mould]]>
I just saw this Instructable about casting metal directly in the printed mould!
http://www.instructables.com/id/3D-Prin ... 73I1K3OJVR
They used the FunToDo industrial blend resin to print the mould and casted Pewter in it.
The Industrial Blend has been tested up to 225C.
The melting point of Pewter is around that temperature (230C) You can get Pewter with a lower melting point.
You might also print some cooling system on it...
This way you can print your own moulds for casting model ship fittings, or your own tin soldiers!
Danny
http://www.funtodo.net
Statistics: Posted by dlp_builder — Tue Nov 25, 2014 2:07 pm
