Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2016-01-07T10:21:37-04:00 http://buildyourownsla.com/forum/feed.php?f=12&t=4866 2016-01-07T10:21:37-04:00 2016-01-07T10:21:37-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4866&p=13992#p13992 <![CDATA[Re: projector resolution problem]]> I'll try it :)
Koom
Statistics: Posted by koom — Thu Jan 07, 2016 10:21 am
2016-01-06T13:35:50-04:00 2016-01-06T13:35:50-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4866&p=13983#p13983 <![CDATA[Re: projector resolution problem]]> Statistics: Posted by James — Wed Jan 06, 2016 1:35 pm
2016-01-04T11:36:53-04:00 2016-01-04T11:36:53-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4866&p=13964#p13964 <![CDATA[projector resolution problem]]> This is my very first 3d printing project.
i try to calibrate 1cm cube with 100micron xy resolution.
i used optoma EX536 (Native Resolution : 1024x768) my build size should be 102.4x76.8 mm
but the build size is 144x108 mm!! in CreationWorkshop output resolution is 141microns
i measure the cube on build area everything ok,1 cm.
when i try to make build size 102.4x76.8 mm but cube bigger than it should be and blur(the focus ring's limited).
what should i do? :cry:
Regards
Koom
Statistics: Posted by koom — Mon Jan 04, 2016 11:36 am
