Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2014-08-06T21:02:11-04:00 http://buildyourownsla.com/forum/feed.php?f=12&t=66 2014-08-06T21:02:11-04:00 2014-08-06T21:02:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=66&p=4551#p4551 <![CDATA[Re: External lamp unit]]> Statistics: Posted by kakapoopie — Wed Aug 06, 2014 9:02 pm
2014-01-25T07:37:58-04:00 2014-01-25T07:37:58-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=66&p=400#p400 <![CDATA[Re: External lamp unit]]>
Statistics: Posted by johnrpm — Sat Jan 25, 2014 7:37 am
2014-01-20T04:09:16-04:00 2014-01-20T04:09:16-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=66&p=336#p336 <![CDATA[Re: External lamp unit]]> its thick paste, is it white light or uv, have you looked inside at the light source?,
if its suitable, you could make an adaptor to the light gate, so you can revert back to the bulb if
needed.
Wouldn't it be nice if we could switch between light sources, I suppose we could have led's on a disk
and dial in the one needed.
Statistics: Posted by johnrpm — Mon Jan 20, 2014 4:09 am
2014-01-19T23:36:17-04:00 2014-01-19T23:36:17-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=66&p=335#p335 <![CDATA[Re: External lamp unit]]> Do you think the optical fiber will transmit UV properly?
Statistics: Posted by seasicksinbad — Sun Jan 19, 2014 11:36 pm
2014-01-19T14:39:08-04:00 2014-01-19T14:39:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=66&p=334#p334 <![CDATA[Re: External lamp unit]]>
The box has one led initialy, but has holes ready for another if needed, the condensing lens was salvaged from an old projector, the second condesing lens came from a 1 watt led torch.
The adaptor is just a disk with 6mm hole for light cable, and clearance screw holes to allow for positioning for best output.
sorry for the poor image quality.
Statistics: Posted by johnrpm — Sun Jan 19, 2014 2:39 pm
2014-01-14T15:21:13-04:00 2014-01-14T15:21:13-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=66&p=291#p291 <![CDATA[External lamp unit]]>
pic's to follow.
Statistics: Posted by johnrpm — Tue Jan 14, 2014 3:21 pm
