Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2016-11-21T02:53:22-04:00 http://buildyourownsla.com/forum/feed.php?f=15 2016-11-21T02:53:22-04:00 2016-11-21T02:53:22-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5524&p=15927#p15927 <![CDATA[Z-Axis and Tillt/Slide axis • Re: Help a New Guy with His Z-Axis? Unable to Get Any Motion.]]>
I am unsure if it is the custom board, or the fact that I am now powering the Easydriver separately that fixed it. I shall do some tests!
Thanks for the help guys.
Statistics: Posted by Ruthalas — Mon Nov 21, 2016 2:53 am
2016-11-19T16:50:51-04:00 2016-11-19T16:50:51-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5524&p=15897#p15897 <![CDATA[Z-Axis and Tillt/Slide axis • Re: Help a New Guy with His Z-Axis? Unable to Get Any Motion.]]>
I am using 115200 as my baud rate, as recommended by the guide I am following.
In GRBL Control this lets me connect and change values:
And in the Arduino serial monitor, it connects and displays the firmware I am using:
Though I can't run any commands... (Probably because I am using non-standard firmware at the moment?)
So I believe the baud rate is set correctly.
What should I look at next?
Statistics: Posted by Ruthalas — Sat Nov 19, 2016 4:50 pm
2016-11-17T05:22:58-04:00 2016-11-17T05:22:58-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5524&p=15894#p15894 <![CDATA[Z-Axis and Tillt/Slide axis • Re: Help a New Guy with His Z-Axis? Unable to Get Any Motion.]]>
download printrun and try to connect or in arduino IDE open the serial monitor (top right corner of the software). Go through the baud rates and figure out which one you have set.
Statistics: Posted by tom-res — Thu Nov 17, 2016 5:22 am
2016-11-19T17:26:42-04:00 2016-11-17T00:21:44-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5524&p=15893#p15893 <![CDATA[Z-Axis and Tillt/Slide axis • Help a New Guy with His Z-Axis? Unable to Get Any Motion.]]> Statistics: Posted by Ruthalas — Thu Nov 17, 2016 12:21 am
2016-08-25T01:42:58-04:00 2016-08-25T01:42:58-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5216&p=15117#p15117 <![CDATA[Z-Axis and Tillt/Slide axis • Cheap/functional Z Axis options??]]> Statistics: Posted by wirelessguyny — Thu Aug 25, 2016 1:42 am
2016-05-31T05:39:04-04:00 2016-05-31T05:39:04-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5100&p=14794#p14794 <![CDATA[Z-Axis and Tillt/Slide axis • The Best Z Axis?]]> Statistics: Posted by Morelli Robotics — Tue May 31, 2016 5:39 am
2016-04-06T06:31:03-04:00 2016-04-06T06:31:03-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14498#p14498 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]>
I wonder if you can get someone from Parker to help you?
Statistics: Posted by James — Wed Apr 06, 2016 6:31 am
2016-02-09T16:31:39-04:00 2016-02-09T16:31:39-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14215#p14215 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]> Statistics: Posted by marwan — Tue Feb 09, 2016 4:31 pm
2016-02-09T06:25:56-04:00 2016-02-09T06:25:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14214#p14214 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]> Statistics: Posted by James — Tue Feb 09, 2016 6:25 am
2016-02-07T17:15:18-04:00 2016-02-07T17:15:18-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14206#p14206 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]> I am trying to built a dlp 3d printer with a linear servo motor (parker mx80l with a vix 250 controler ) resolution is 10 nano . Any idea ?
Statistics: Posted by marwan — Sun Feb 07, 2016 5:15 pm
2016-02-04T10:01:51-04:00 2016-02-04T10:01:51-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14191#p14191 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]>
A servo (RC type) would work fine. I think Kvirre was thinking you were talking about Z axis liner motion, which would never work.
Statistics: Posted by James — Thu Feb 04, 2016 10:01 am
2016-02-04T09:06:58-04:00 2016-02-04T09:06:58-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14188#p14188 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]> Thank You for Your answer. Why do You think that servo will not work well? The drawer will be installed on rails, servo will only move the drawer on these rails. Can You explain more? Maybe I do not know as much as I think.
Kind Regards,
Arek
Statistics: Posted by Arco — Thu Feb 04, 2016 9:06 am
2016-02-04T06:18:38-04:00 2016-02-04T06:18:38-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14186#p14186 <![CDATA[Z-Axis and Tillt/Slide axis • Re: The best tilt option?]]> (moves constantly according to pulse-with).
You may end up with striping along z-axis.
Statistics: Posted by Kvirre — Thu Feb 04, 2016 6:18 am
2016-02-03T14:33:58-04:00 2016-02-03T14:33:58-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4951&p=14182#p14182 <![CDATA[Z-Axis and Tillt/Slide axis • The best tilt option?]]> I am fighting with project of my printer and I have got little problem. I want to make the best DLP printer as I can for super high quality prints but...
Can You tell me what is the most important tilt role? Is it made for break away print from tank like some people says or the most important role is to provide fresh resin or something more???
I am asking because I am little bit in the drop. I wanted to create something similar to B9 drawer using 10mm shaft and bearing. It would safe me a lot of time with shutter - I would use 1 servo for drawer move when projector will not work.
Can anyone help me?
Here is it first few.
Cheers,
Arek
Statistics: Posted by Arco — Wed Feb 03, 2016 2:33 pm
2015-08-25T04:17:26-04:00 2015-08-25T04:17:26-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=62&p=11994#p11994 <![CDATA[Z-Axis and Tillt/Slide axis • Re: My tilt mechanism]]> Statistics: Posted by otsoa — Tue Aug 25, 2015 4:17 am
