Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2018-10-17T12:00:44-04:00 http://buildyourownsla.com/forum/feed.php?f=16 2018-10-17T12:00:44-04:00 2018-10-17T12:00:44-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=12643&p=27519#p27519 <![CDATA[Vat Design and Construction • Re: Heated Resin VAT?]]> Statistics: Posted by James — Wed Oct 17, 2018 12:00 pm
2018-10-13T14:06:14-04:00 2018-10-13T14:06:14-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=12643&p=27517#p27517 <![CDATA[Vat Design and Construction • Heated Resin VAT?]]> Statistics: Posted by Finhead — Sat Oct 13, 2018 2:06 pm
2018-03-02T15:55:25-04:00 2018-03-02T15:55:25-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=11844&p=26667#p26667 <![CDATA[Vat Design and Construction • Re: Printing possible without vat?]]>
2. No, the resin is like glue. Once the light polymerizes the resin anything the resin is touching sticks to it extremely well. Consequently, a nonstick surface is needed when doing bottom up SLA. One thing that can be done is to float the resin on another heaver liquid, this has been done before and lets one do top down SLA without having to use a lot of resin to fill up a deep vat.
3. Hmmm. . . You would need to make the whole printer move as the build took place or you would need to make the part as it was being built move away from the printer as it was being built. So, you would need something like a bottom up method with a nonstick transparent conveyor belt that you would coat with a thin layer of resin for each layer cycle. In the making the printer move as the part was built would need to print a scaffold that the printer would reside on and the scaffold would continue to be built along with the part being printed.
Statistics: Posted by James — Fri Mar 02, 2018 3:55 pm
2018-02-18T16:13:31-04:00 2018-02-18T16:13:31-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=11844&p=26531#p26531 <![CDATA[Vat Design and Construction • Printing possible without vat?]]>
I have two questions:
1)Is there any way to make printer without vat.
2)Can i use slim plexiglass rather than flexvat etc.
3)Can i find a infinite solution for vat system?
Statistics: Posted by mutu3d — Sun Feb 18, 2018 4:13 pm
2017-12-17T19:04:08-04:00 2017-12-17T19:04:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2193&p=24757#p24757 <![CDATA[Vat Design and Construction • Re: PP/Polypropylene/ foil for VAT buttom]]> Statistics: Posted by Kyrian — Sun Dec 17, 2017 7:04 pm
2017-10-26T08:16:52-04:00 2017-10-26T08:16:52-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2193&p=22269#p22269 <![CDATA[Vat Design and Construction • Re: PP/Polypropylene/ foil for VAT buttom]]>
Currently printing on 80 micron PP sheets (cut from simple glass clear A5 document protectors)
https://www.amazon.de/Rexel-1300063-Pro ... ds=1300063
So far so good. I don't have direct comparison prints with FEP yet. Should be happening in the next few weeks, but with the Eiffel tower scaled to a 38x38mm footprint base, the internal supports are coming out pretty well even with a less than optimal Acer H6500 setup.
Statistics: Posted by leitnin — Thu Oct 26, 2017 8:16 am
2017-08-28T19:19:08-04:00 2017-08-28T19:19:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1311&p=21198#p21198 <![CDATA[Vat Design and Construction • Re: FormLabs Vat Design]]> Statistics: Posted by Tarantulae — Mon Aug 28, 2017 7:19 pm
2017-03-16T06:27:39-04:00 2017-03-16T06:27:39-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1706&p=17028#p17028 <![CDATA[Vat Design and Construction • Re: where to buy FEP in Europe]]> Statistics: Posted by fepshop — Thu Mar 16, 2017 6:27 am
2017-02-08T10:18:39-04:00 2017-02-08T10:18:39-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5700&p=16697#p16697 <![CDATA[Vat Design and Construction • FEP for Flex VAT from Aliexpress]]> Where I can buy FEP for my Flex VAT?
I need A4 size 300*200mm
Any one know good seller at aliexpress?
Statistics: Posted by 3dprinter.org.ua — Wed Feb 08, 2017 10:18 am
2017-01-20T21:26:53-04:00 2017-01-20T21:26:53-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5672&p=16544#p16544 <![CDATA[Vat Design and Construction • Re: FEP Cutting.]]> Statistics: Posted by hp_ — Fri Jan 20, 2017 9:26 pm
2017-01-20T14:59:51-04:00 2017-01-20T14:59:51-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5672&p=16543#p16543 <![CDATA[Vat Design and Construction • FEP Cutting.]]>
I assume most of you are using a laser cutter?
I see there are these desktop cutters by Silhouette. You can use .dxf files on there but I would be interested to know if anyone has used one to cut their FEP and also 1mm craft foam for seals (HTL vat).
Statistics: Posted by hirenashra — Fri Jan 20, 2017 2:59 pm
2016-12-05T07:20:39-04:00 2016-12-05T07:20:39-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2500&p=16073#p16073 <![CDATA[Vat Design and Construction • Re: My answer to the FEP vat challenge]]> Statistics: Posted by abk101095 — Mon Dec 05, 2016 7:20 am
2016-10-29T19:13:54-04:00 2016-10-29T19:13:54-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5483&p=15717#p15717 <![CDATA[Vat Design and Construction • FSL3d Pegasus Touch vats?]]> Statistics: Posted by doobie — Sat Oct 29, 2016 7:13 pm
2016-09-21T17:23:08-04:00 2016-09-21T17:23:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5384&p=15420#p15420 <![CDATA[Vat Design and Construction • Re: Vat options for a newly built SLA printer?]]> Statistics: Posted by jbase — Wed Sep 21, 2016 5:23 pm
2016-09-21T12:38:19-04:00 2016-09-21T12:38:19-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5384&p=15418#p15418 <![CDATA[Vat Design and Construction • Re: Vat options for a newly built SLA printer?]]> Statistics: Posted by HTL — Wed Sep 21, 2016 12:38 pm
