Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-02-12T02:59:08-04:00 http://buildyourownsla.com/forum/feed.php?f=19&t=2151 2015-02-12T02:59:08-04:00 2015-02-12T02:59:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8273#p8273 <![CDATA[Re: First prints! Starting to print.]]> only problem is it has a 50% chance of not having enough force to unstick from the vat, its a work in progress lol
Statistics: Posted by JSmith172 — Thu Feb 12, 2015 2:59 am
2015-02-11T19:11:21-04:00 2015-02-11T19:11:21-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8268#p8268 <![CDATA[Re: First prints! Starting to print.]]> Statistics: Posted by goopyplastic — Wed Feb 11, 2015 7:11 pm
2015-02-07T14:31:56-04:00 2015-02-07T14:31:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8203#p8203 <![CDATA[Re: First prints! Starting to print.]]>
Statistics: Posted by JSmith172 — Sat Feb 07, 2015 2:31 pm
2015-02-05T04:41:18-04:00 2015-02-05T04:41:18-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8140#p8140 <![CDATA[Re: First prints! Starting to print.]]> will post results
Statistics: Posted by JSmith172 — Thu Feb 05, 2015 4:41 am
2015-02-04T16:55:08-04:00 2015-02-04T16:55:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8130#p8130 <![CDATA[Re: First prints! Starting to print.]]>
You should be able to see the metal build plate through the bottom of the petri (by looking into the mirror). Does that help?
Statistics: Posted by Scatterplot — Wed Feb 04, 2015 4:55 pm
2015-02-04T15:08:01-04:00 2015-02-04T15:08:01-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8127#p8127 <![CDATA[Re: First prints! Starting to print.]]> Statistics: Posted by fraggle68 — Wed Feb 04, 2015 3:08 pm
2015-02-04T14:00:23-04:00 2015-02-04T14:00:23-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8125#p8125 <![CDATA[Re: First prints! Starting to print.]]> Statistics: Posted by Scatterplot — Wed Feb 04, 2015 2:00 pm
2015-02-04T13:35:44-04:00 2015-02-04T13:35:44-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=8124#p8124 <![CDATA[Re: First prints! Starting to print.]]> I am a new owner of the littleRP a got a lot of problems by calibration the z axis. Do you have a tip how to calibrate the dishes and the object holder. whats the exact space between the dish and the z axis and is there a possibility to save it.
Thanks for our help
Kai
Statistics: Posted by fraggle68 — Wed Feb 04, 2015 1:35 pm
2014-11-28T23:53:40-04:00 2014-11-28T23:53:40-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6374#p6374 <![CDATA[Re: First prints! Starting to print.]]>
Have you used the 10mm grid projection image to test your projector distance/focus?
Statistics: Posted by PomeroyB — Fri Nov 28, 2014 11:53 pm
2014-11-28T12:18:48-04:00 2014-11-28T12:18:48-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6367#p6367 <![CDATA[Re: First prints! Starting to print.]]>
Boy I love windows 8. For some reason my laptop loves to change the settings when it restarts and this time it decided to turn off my monitor after 10 minutes of inactivity so I wasted some time this morning. I printed the following test from the LittleRP site. Again, the dimensions are slightly off but the surface finish on it is amazing.
Statistics: Posted by mammasan — Fri Nov 28, 2014 12:18 pm
2014-11-27T11:33:02-04:00 2014-11-27T11:33:02-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6349#p6349 <![CDATA[Re: First prints! Starting to print.]]>
Printing with funtodo resin industrial blend. My initial settings were too high and the resin stuck to and ripped the pdms layer. I changed my settings to the following: 4500 for first 8 layers, 800 for rest of layers with 50 micron z resolution. This seems to be working out fine although I think I may be able to decrease the time a little bit. I printed the calibration from the littlerp website and then printed a dental model. Measuring them they are both slightly oversized. The cylinders should be 2mm (as measured in netfabb) an they are about 2.2-2.3 mm. They are mostly round and straight. The dental model that has the cylinder should be 2.2mm and it is closer to 2.8. Otherwise the prints all look pretty good.
So where do I go from here? I am thinking I need to reduce the exposure time and work on making sure the projector is in perfect focus. I will grab better photos after the weekend, my dslr/macro setup is at my office.
Statistics: Posted by mammasan — Thu Nov 27, 2014 11:33 am
2014-11-26T15:59:31-04:00 2014-11-26T15:59:31-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6323#p6323 <![CDATA[Re: First prints! Starting to print.]]>
Got my LittleRP yesterday and assembled it during work. Hope to start printing tonight. Build was fairly easy, probably would have taken 2 hours straight but I did it in between patients.
Statistics: Posted by mammasan — Wed Nov 26, 2014 3:59 pm
2014-11-18T21:47:06-04:00 2014-11-18T21:47:06-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6165#p6165 <![CDATA[Re: First prints! Starting to print.]]> Statistics: Posted by mammasan — Tue Nov 18, 2014 9:47 pm
2014-11-18T16:04:37-04:00 2014-11-18T16:04:37-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6159#p6159 <![CDATA[Re: First prints! Starting to print.]]> I tried this one before, maybe this will help you also:
Free to download the calibration part at:
Statistics: Posted by EdgE — Tue Nov 18, 2014 4:04 pm
2014-11-18T04:20:20-04:00 2014-11-18T04:20:20-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2151&p=6157#p6157 <![CDATA[Re: First prints! Starting to print.]]> Statistics: Posted by Kvirre — Tue Nov 18, 2014 4:20 am
