[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 574: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 630: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/feed.php on line 195: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937) [phpBB Debug] PHP Warning: in file [ROOT]/feed.php on line 196: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937) Build Your Own SLA/SLSA forum dedicated to helping you build your own SLA/SLS-based 3d printer2015-02-07T23:18:58-04:00http://buildyourownsla.com/forum/feed.php?f=19&t=26562015-02-07T23:17:56-04:002015-02-07T23:17:56-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8214#p8214 slight off angle caused by a cross threaded screw on bottom thanks guys
Statistics: Posted by JSmith172 — Sat Feb 07, 2015 11:17 pm
]]>2015-02-07T20:41:07-04:002015-02-07T20:41:07-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8213#p8213Statistics: Posted by Phife — Sat Feb 07, 2015 8:41 pm
]]>2015-02-07T14:34:30-04:002015-02-07T14:34:30-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8204#p8204or could it be mechanical? could my balls be out of line on my rails?
Statistics: Posted by JSmith172 — Sat Feb 07, 2015 2:34 pm
]]>2015-02-07T11:47:14-04:002015-02-07T11:47:14-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8197#p8197Statistics: Posted by maurice — Sat Feb 07, 2015 11:47 am
]]>2015-02-07T05:33:09-04:002015-02-07T05:33:09-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8189#p8189Statistics: Posted by JSmith172 — Sat Feb 07, 2015 5:33 am
]]>2015-02-06T18:06:17-04:002015-02-06T18:06:17-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8180#p8180Statistics: Posted by JSmith172 — Fri Feb 06, 2015 6:06 pm
]]>2015-02-06T12:39:50-04:002015-02-06T12:39:50-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8176#p8176Statistics: Posted by Scatterplot — Fri Feb 06, 2015 12:39 pm
]]>2015-02-06T12:31:16-04:002015-02-06T12:31:16-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8175#p8175
Statistics: Posted by JSmith172 — Fri Feb 06, 2015 12:31 pm
]]>2015-02-06T11:50:44-04:002015-02-06T11:50:44-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8173#p8173Statistics: Posted by Scatterplot — Fri Feb 06, 2015 11:50 am
]]>2015-02-07T23:18:58-04:002015-02-06T02:28:58-04:00http://buildyourownsla.com/forum/viewtopic.php?t=2656&p=8163#p8163Statistics: Posted by JSmith172 — Fri Feb 06, 2015 2:28 am
