Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-03-20T19:22:15-04:00 http://buildyourownsla.com/forum/feed.php?f=19&t=2780 2015-03-20T19:22:15-04:00 2015-03-20T19:22:15-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=9047#p9047 <![CDATA[Re: only right half of machine working ?]]> Statistics: Posted by goopyplastic — Fri Mar 20, 2015 7:22 pm
2015-03-20T01:35:08-04:00 2015-03-20T01:35:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=9020#p9020 <![CDATA[Re: only right half of machine working ?]]> Statistics: Posted by JSmith172 — Fri Mar 20, 2015 1:35 am
2015-03-18T14:20:46-04:00 2015-03-18T14:20:46-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=8958#p8958 <![CDATA[Re: only right half of machine working ?]]>
It is possible that there is uneveness in the focus / projection intensity. Creation Workshop has introduced masks that let you compensate for this. Ie. the projection image would be brighter on the outside of the print, and darker in the middle to try and even things out. You could do a similar thing for right to left variance etc.
I find the acer 1080p projectors really have a sharpness sweetspot in the center and tend to be worse on the left side than the right so in your case I would probably just print 1 ring centered, two centered standing up with supports, increase overall cure time to meet the lowest common denominator, or look into using a mask.
Great looking prints though, have you tried burning out the castsolid yet?
Statistics: Posted by goopyplastic — Wed Mar 18, 2015 2:20 pm
2015-03-17T01:40:04-04:00 2015-03-17T01:40:04-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=8869#p8869 <![CDATA[Re: only right half of machine working ?]]> so im guessing uneven exposure
i'm using the H6510BD in the closest pin postion
any other way other than over exposure? adding more time just cause the working side to fail
Statistics: Posted by JSmith172 — Tue Mar 17, 2015 1:40 am
2015-03-16T19:07:30-04:00 2015-03-16T19:07:30-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=8864#p8864 <![CDATA[Re: only right half of machine working ?]]> Statistics: Posted by Scatterplot — Mon Mar 16, 2015 7:07 pm
2015-03-16T18:51:32-04:00 2015-03-16T18:51:32-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=8863#p8863 <![CDATA[Re: only right half of machine working ?]]> the supports are always fine
Statistics: Posted by JSmith172 — Mon Mar 16, 2015 6:51 pm
2015-03-16T02:30:49-04:00 2015-03-16T02:30:49-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=8833#p8833 <![CDATA[Re: only right half of machine working ?]]> Statistics: Posted by PomeroyB — Mon Mar 16, 2015 2:30 am
2015-03-15T23:38:41-04:00 2015-03-15T23:38:41-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2780&p=8830#p8830 <![CDATA[only right half of machine working ?]]> Statistics: Posted by JSmith172 — Sun Mar 15, 2015 11:38 pm
