Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-09-16T14:26:11-04:00 http://buildyourownsla.com/forum/feed.php?f=19&t=2939 2015-09-16T14:26:11-04:00 2015-09-16T14:26:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=12464#p12464 <![CDATA[Re: Acer P1500 settings?]]> Without mask, light distribution deviation was from 35 to 80 points (whole range: 0..255). With not-so-good mask it drops to 35-45 points.
But I printed only one model with my mask. For some reason, I can't properly load mask file now. Maybe problems with file permissions in Windows, or a bug in CW. :(
But I think, generally, that grey mask is able to solve uneven light issue.
Statistics: Posted by DanOrgan — Wed Sep 16, 2015 2:26 pm
2015-09-16T03:17:32-04:00 2015-09-16T03:17:32-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=12454#p12454 <![CDATA[Re: Acer P1500 settings?]]>
I have the same problems with uneven light distribution (ACER 6510). :cry:
Anything new on that? Does Creation Workshop support gray masks?
Statistics: Posted by lab — Wed Sep 16, 2015 3:17 am
2015-08-08T10:00:28-04:00 2015-08-08T10:00:28-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11639#p11639 <![CDATA[Re: Acer P1500 settings?]]> Statistics: Posted by DanOrgan — Sat Aug 08, 2015 10:00 am
2015-08-06T17:15:56-04:00 2015-08-06T17:15:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11586#p11586 <![CDATA[Re: Acer P1500 settings?]]> Statistics: Posted by sodium — Thu Aug 06, 2015 5:15 pm
2015-08-06T03:22:56-04:00 2015-08-06T03:22:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11574#p11574 <![CDATA[Re: Acer P1500 settings?]]> I purchased cheap $10 Arduino-compatible UV-sensor from (sorry, Russian site). Maybe it will be useful.
Statistics: Posted by DanOrgan — Thu Aug 06, 2015 3:22 am
2015-08-05T19:56:37-04:00 2015-08-05T19:56:37-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11565#p11565 <![CDATA[Re: Acer P1500 settings?]]> Statistics: Posted by goopyplastic — Wed Aug 05, 2015 7:56 pm
2015-08-06T03:03:50-04:00 2015-08-05T13:00:53-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11556#p11556 <![CDATA[Re: Acer P1500 settings?]]> Image
But how to make good exposure mask? I saw some kind of light sensor on Envisiontec 3d printers, it was used during calibration. Maybe, we need some hardware too, for this purpose.
Statistics: Posted by DanOrgan — Wed Aug 05, 2015 1:00 pm
2015-07-20T12:49:06-04:00 2015-07-20T12:49:06-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11185#p11185 <![CDATA[Re: Acer P1500 settings?]]>
Perhaps applying a mask in Creation workshop to the "good" area, and upping the exposure overall would even it out (at the cost of print time)
Statistics: Posted by Wonderdog — Mon Jul 20, 2015 12:49 pm
2015-07-14T11:39:07-04:00 2015-07-14T11:39:07-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=11071#p11071 <![CDATA[Re: Acer P1500 settings?]]> Were you able to play with the projector settings at all? I have been messing with mine a little bit and am having a hard time finding a good consistent setting. I'm either under or overexposing. I'm using the H6510BD printer and madesolid V2 Red resin. I tried a few of the brighter modes, but got overexposure and bleeding in the center. Just trying to find a good starting point again.
Statistics: Posted by mostlydiy — Tue Jul 14, 2015 11:39 am
2015-05-03T17:59:57-04:00 2015-05-03T17:59:57-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=9793#p9793 <![CDATA[Re: Acer P1500 settings?]]> Statistics: Posted by Kochen — Sun May 03, 2015 5:59 pm
2015-05-02T01:46:51-04:00 2015-05-02T01:46:51-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=9776#p9776 <![CDATA[Re: Acer P1500 settings?]]>
I've basically got it on default projector settings. I have noticed that is uneven. Center/right is best left has problems with being underexposed. Not sure if there is anything that can be done. If i crank it up so the left is exposed properly, the right gets overexposed.
Statistics: Posted by james_lan — Sat May 02, 2015 1:46 am
2015-05-01T13:26:32-04:00 2015-05-01T13:26:32-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=9773#p9773 <![CDATA[Re: Acer P1500 settings?]]> Statistics: Posted by goopyplastic — Fri May 01, 2015 1:26 pm
2015-05-01T06:31:26-04:00 2015-05-01T06:31:26-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2939&p=9767#p9767 <![CDATA[Acer P1500 settings?]]>
I'm using the Acer P1500 with my LittleRP and was wondering if others that uses the same projector have played with specific settings in the menu for the projector to get better results, besides focusing on the lens and maybe moving the projector a hole or two backwards?
Statistics: Posted by Kochen — Fri May 01, 2015 6:31 am
