Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-12-30T02:58:10-04:00 http://buildyourownsla.com/forum/feed.php?f=19&t=4745 2015-12-30T02:58:10-04:00 2015-12-30T02:58:10-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13941#p13941 <![CDATA[Re: Printing flat surfaces z axis]]> __________________________________________________________________________________
Statistics: Posted by shishakie3 — Wed Dec 30, 2015 2:58 am
2015-10-23T05:28:11-04:00 2015-10-23T05:28:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13580#p13580 <![CDATA[Re: Printing flat surfaces z axis]]> Statistics: Posted by nalmeida — Fri Oct 23, 2015 5:28 am
2015-10-19T11:57:09-04:00 2015-10-19T11:57:09-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13567#p13567 <![CDATA[Re: Printing flat surfaces z axis]]> Statistics: Posted by nalmeida — Mon Oct 19, 2015 11:57 am
2015-10-19T09:37:07-04:00 2015-10-19T09:37:07-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13565#p13565 <![CDATA[Re: Printing flat surfaces z axis]]> Looking at the individual slice files helps resolve many questions why prints do what they do. I once was pulling my hair out on why a feature was not printing and when I looked at the slice images I realized why (not enough pixels exposing one feature).
Dan
Statistics: Posted by dangre — Mon Oct 19, 2015 9:37 am
2015-10-18T07:19:29-04:00 2015-10-18T07:19:29-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13556#p13556 <![CDATA[Re: Printing flat surfaces z axis]]>
try printing at a smaller scale and see what happens, or rotate it a few degrees around the Z axis. I'm certain the artifacts disappear when you rotate around z (not 90 degrees tho..some odd number)
Statistics: Posted by adambx — Sun Oct 18, 2015 7:19 am
2015-10-18T05:14:41-04:00 2015-10-18T05:14:41-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13555#p13555 <![CDATA[Re: Printing flat surfaces z axis]]>
I looked at the STL and it looks perfect. Each panel is composed of two triangles so there is no problem there.
What I see when slicing with standard settings and looking through the slices in the slice viewer is that the X,Y resolution is too low to make the walls perfectly flat. If the walls were situated to where they were perfectly parallel to the Z axis then it would work fine. But the model is slightly skewed and so the pixels make a stair stepping effect. If you look at it in slice view and slowly scroll through the slices you can see the pixels stair steps moving left and right along the panels in the exact pattern that you see on your prints.
Statistics: Posted by James — Sun Oct 18, 2015 5:14 am
2015-10-17T03:50:02-04:00 2015-10-17T03:50:02-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13550#p13550 <![CDATA[Re: Printing flat surfaces z axis]]>
I'm using 1.5 antialiasing, is this relevant?
I also thought about the STL but nothing appears when the surfaces are facing with the x/y axis!!
I'm attaching the STL of the planes anyway, maybe there's something I'm missing!
506_DLP_LATERAL.zip
Statistics: Posted by nalmeida — Sat Oct 17, 2015 3:50 am
2015-10-16T17:23:52-04:00 2015-10-16T17:23:52-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13547#p13547 <![CDATA[Re: Printing flat surfaces z axis]]> Statistics: Posted by redonix76 — Fri Oct 16, 2015 5:23 pm
2015-10-15T20:55:20-04:00 2015-10-15T20:55:20-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13542#p13542 <![CDATA[Re: Printing flat surfaces z axis]]>
Just kidding. The "exactness" of the lines makes me think it's a problem in the export of the file to a STL as STLs are a collection of triangles.
Statistics: Posted by nc42 — Thu Oct 15, 2015 8:55 pm
2015-10-15T14:17:37-04:00 2015-10-15T14:17:37-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13540#p13540 <![CDATA[Re: Printing flat surfaces z axis]]> Statistics: Posted by dangre — Thu Oct 15, 2015 2:17 pm
2015-10-15T10:57:09-04:00 2015-10-15T10:57:09-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13539#p13539 <![CDATA[Re: Printing flat surfaces z axis]]>
This refers to the second picture:
Statistics: Posted by nalmeida — Thu Oct 15, 2015 10:57 am
2015-10-15T10:43:05-04:00 2015-10-15T10:43:05-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13538#p13538 <![CDATA[Re: Printing flat surfaces z axis]]> Statistics: Posted by Scatterplot — Thu Oct 15, 2015 10:43 am
2015-10-15T09:44:08-04:00 2015-10-15T09:44:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4745&p=13537#p13537 <![CDATA[Printing flat surfaces z axis]]>
As can be seen in the picture below on the panels between the lines there are some artifacts, on the stl this area is perfectly still so I don't understand why these "triangles" appear! This only happens on the Z axis, on the x/y flat panels are flat.
Thanks for your help.
Statistics: Posted by nalmeida — Thu Oct 15, 2015 9:44 am
