Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2017-01-03T19:44:45-04:00 http://buildyourownsla.com/forum/feed.php?f=19&t=5647 2017-01-03T19:44:45-04:00 2017-01-03T19:44:45-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16414#p16414 <![CDATA[Re: No Consistent Success - SOMEBODY HELP!!!]]>
However, shortly after using some of it, I found out that it does not play nice with platinum cure silicone. Which given what I do, makes it mostly useless to me. Which led me to MadeSolid's stuff (who of which I think is currently going under business reconstruction) but couldn't get any of that, so I went with FTD. I originally wanted Snow White, but everyone was sold out. So I got black.
I'm about to run a test print with about half the cure time (1250 -> 500) and without the mask. The more I read about this stuff, the more it seems like this stuff is even more sensitive than I thought. This stuff is supposed to work and make clean prints without adding more pigment and other people have had success, so there's most likely some optimum combination of settings that I just haven't hit yet.
My projector is a Viewsonic PJD7820HD, stock lens, with a modified color wheel Maybe try putting the original stock lens on. If I remember correctly, the P1500 was one of the two models that needed no modification to use.
EDIT: I WAS RIGHT. The makers of the resin posted some calibration tips, among other things. This should help a lot.
ANOTHER EDIT: and a
Statistics: Posted by Head-Zonk Studios — Tue Jan 03, 2017 7:44 pm
2017-01-03T19:18:32-04:00 2017-01-03T19:18:32-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16413#p16413 <![CDATA[Re: No Consistent Success - SOMEBODY HELP!!!]]>
I'm thinking it could be because of the close up lens i added. I used it so that I could use more of the build plate. The Acer P1500 doesn't focus well at the top. Now what might be happening is the UV light bending causing dead spots.
The mask will be useful on this occasion. HTL has some software he created for such a purpose.
https://flexvat.com/pages/diy-and-techn ... %20Program
Interestingly enough, I've used FTD black and I got a successful print out of it. Probably the only time I did! 8-)
Have you tried other resins?
Statistics: Posted by hirenashra — Tue Jan 03, 2017 7:18 pm
2017-01-03T14:11:47-04:00 2017-01-03T14:11:47-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16412#p16412 <![CDATA[Re: No Consistent Success - SOMEBODY HELP!!!]]>
The mask is an image used to filter out a measure of the light in certain areas of the projected images. Look at these threads here, they explain it better than I can. It's basically a means of making the light distribution a little more even.
I think I've had some improvement using the mask, but it's creating these weird scan lines. I can see the lines in the projected image when it's blown up, and now because of the super high reactivity of the FTD resin, the prints are picking up a subtle wavy surface.
Worse still, I am now facing some really, really bad exposure bleed, as have other FTD users.
It's most pronounced in the areas where the supports connect to the model, and really just any area where things are getting bigger as the print builds. I might be able to file things out for these pieces, but really, these pieces were made to fit closely together. I need things to be exact, not just for this, but for future projects.
I thought about lowering the exposure time, but I'm afraid it won't cure enough to peel off the vat. I'm thinking I need to add more pigment to the resin to increase the light absorption.
Statistics: Posted by Head-Zonk Studios — Tue Jan 03, 2017 2:11 pm
2017-01-03T05:24:08-04:00 2017-01-03T05:24:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16411#p16411 <![CDATA[Re: No Consistent Success - SOMEBODY HELP!!!]]> Statistics: Posted by hirenashra — Tue Jan 03, 2017 5:24 am
2017-01-02T22:36:20-04:00 2017-01-02T22:36:20-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16408#p16408 <![CDATA[Re: No Consistent Success - SOMEBODY HELP!!!]]> Statistics: Posted by Head-Zonk Studios — Mon Jan 02, 2017 10:36 pm
2017-01-02T19:07:35-04:00 2017-01-02T19:07:35-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16406#p16406 <![CDATA[Re: No Consistent Success - SOMEBODY HELP!!!]]> Statistics: Posted by hirenashra — Mon Jan 02, 2017 7:07 pm
2016-12-30T03:39:57-04:00 2016-12-30T03:39:57-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5647&p=16382#p16382 <![CDATA[No Consistent Success - SOMEBODY HELP!!!]]>
The problem I'm having is with the flex vat. It will not stop sticking to the bottom of the vat, but it does fully adhere to the build plate. I thought it was manageable as I had gotten one fully successful print out of it. I tried printing the same model again from a different angle (the supports had some negative effects on some details), but with the lamp on econo-mode in an attempt to stop the sticking. It was still sticking to the bottom and the print failed. All of the supports formed but none of the actual model did.
I cleaned it out and set the lamp back to normal, but pretty much the same thing happened. It was sticking and the print failed again. Only bits and pieces formed and I was left with a thin sheet in an outline of the model hanging from the highest support.
Getting this machine to work has been a near nightmare. I thought I was finally getting somewhere having finally successfully made something that wasn't a test brick, but I cannot get any sort of consistency out of it. I've tried everything. Adjusting brightness, adjusting the exposure time, removing the color wheel, repositioning the model, thickening the points where the model meets the supports, more supports, two different resins...
I don't know what else to do! Do I need a more stable work area than my desk? Is slight jiggling what's been causing me so much trouble? Is the resin getting to warm? Has the FEP sheet been damaged somehow by the resin sticking?
Statistics: Posted by Head-Zonk Studios — Fri Dec 30, 2016 3:39 am
