Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2016-07-10T18:05:15-04:00 http://buildyourownsla.com/forum/feed.php?f=20 2016-07-10T18:05:15-04:00 2016-07-10T18:05:15-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=5155&p=14951#p14951 <![CDATA[Uncia • Flip your Uncia to Down Top system]]>
Benefits:
The increase in the quality of all your impressions, by completely eliminating the surface tension.
Save money when buying small amounts of resin. Now you can purchase different types and from different vendors without the need to buy at least two liters
Overall increase in performance of your printer.
And finally, a more professional and nice view.
The first step will be to disarm the inner corner where the stepper motor and platform construction is currently supported.
This piece will not use more. We require all the space in the bottom of the printer to stay there the projector.
You need everything at hand, all printed pieces, pieces of MDF and screws required for assembly.
Begin to understand the plans is the best idea. Please note that construction time will be about 5 0 6 hours. Have patience.
With the help of the drawings and measurements, make holes to your printer. You can start with the base supports, always correcting your measurements before drilling.
Be sure to use the right tool and a good metal bracket to make holes very precisely that depends as you do not have problems later.
Good luck
http://www.thingiverse.com/thing:1667124
Statistics: Posted by firecardenal — Sun Jul 10, 2016 6:05 pm
2016-01-14T17:37:28-04:00 2016-01-14T17:37:28-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4917&p=14067#p14067 <![CDATA[Uncia • DrumHead FlexVat for Top_Down printer.]]>
Download the files on:
http://www.thingiverse.com/thing:1268783
Statistics: Posted by firecardenal — Thu Jan 14, 2016 5:37 pm
2015-10-28T02:52:14-04:00 2015-10-28T02:52:14-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4259&p=13602#p13602 <![CDATA[Uncia • Re: Problems with Acer X1173 and Makerjuice G+]]> Statistics: Posted by polbo — Wed Oct 28, 2015 2:52 am
2015-10-10T01:04:13-04:00 2015-10-10T01:04:13-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4259&p=12953#p12953 <![CDATA[Uncia • Re: Problems with Acer X1173 and Makerjuice G+]]> Statistics: Posted by James — Sat Oct 10, 2015 1:04 am
2015-10-09T12:43:13-04:00 2015-10-09T12:43:13-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4259&p=12932#p12932 <![CDATA[Uncia • Re: Problems with Acer X1173 and Makerjuice G+]]>
Statistics: Posted by polbo — Fri Oct 09, 2015 12:43 pm
2015-10-09T01:04:11-04:00 2015-10-09T01:04:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4259&p=12911#p12911 <![CDATA[Uncia • Re: Problems with Acer X1173 and Makerjuice G+]]> Statistics: Posted by James — Fri Oct 09, 2015 1:04 am
2015-10-07T14:21:29-04:00 2015-10-07T14:21:29-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4259&p=12850#p12850 <![CDATA[Uncia • Problems with Acer X1173 and Makerjuice G+]]> ssorry for my English... I don't speak English very well.
I've a Uncia DLP printer witn Acer X1173 projector. Last month I bought a Makerjuice G+ red resin.
I'm not able to have a good print quality and i understand which is the problem. In the internal menu, I set the projector with standard video propreties. Resolution is 1024X768.
My CW configuration is:
Slice thickness: 0,1mm
Exposure time per Layer: 6000ms
Bottom Layers Exposure time: 10000ms
#layers: 3
Enable Anti-Aliasing: activate (1.5)
Export images & GCode: activate
Lift and Sequence time: 10600ms
Z lift distance: 5mm
Build direction: bottom up
Z lift speed: 50mm/m
Z lift retract speed: 100 mm/m
Slide/tilt value:0
Can you help me?
Statistics: Posted by polbo — Wed Oct 07, 2015 2:21 pm
2015-07-27T23:16:35-04:00 2015-07-27T23:16:35-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3507&p=11338#p11338 <![CDATA[Uncia • Uncia DLP 3D printer Full review]]> You will find all the desings on my Thingiverse channel.
Thanks for watching.
https://www.youtube.com/watch?v=vRaSqut ... e=youtu.be
UV Light Station.
http://www.thingiverse.com/thing:942997
Printing Platform.
http://www.thingiverse.com/thing:942754
Cleaning Station.
http://www.thingiverse.com/thing:942537
Extraction System.
http://www.thingiverse.com/thing:941964
Main Column
http://www.thingiverse.com/thing:910771
Rotation Microswitch
http://www.thingiverse.com/thing:509094
Levelers
http://www.thingiverse.com/thing:447842
Light filters
http://www.thingiverse.com/thing:444189
Statistics: Posted by firecardenal — Mon Jul 27, 2015 11:16 pm
2015-07-16T14:20:52-04:00 2015-07-16T14:20:52-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=11128#p11128 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]>
The platform construction is slightly flexible. This helps to simulate a little tilt movement.
Maybe in a future version add a passive tilt mechanism.
Statistics: Posted by firecardenal — Thu Jul 16, 2015 2:20 pm
2015-07-16T12:47:00-04:00 2015-07-16T12:47:00-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=11125#p11125 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]> Statistics: Posted by Joerg — Thu Jul 16, 2015 12:47 pm
2015-07-11T10:57:35-04:00 2015-07-11T10:57:35-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=10993#p10993 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]> Statistics: Posted by firecardenal — Sat Jul 11, 2015 10:57 am
2015-07-09T18:16:47-04:00 2015-07-09T18:16:47-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=10962#p10962 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]> Statistics: Posted by newraper1963 — Thu Jul 09, 2015 6:16 pm
2015-07-09T14:58:00-04:00 2015-07-09T14:58:00-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=10959#p10959 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]> Statistics: Posted by dangre — Thu Jul 09, 2015 2:58 pm
2015-07-08T13:53:39-04:00 2015-07-08T13:53:39-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=10926#p10926 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]> Statistics: Posted by firecardenal — Wed Jul 08, 2015 1:53 pm
2015-07-08T13:39:56-04:00 2015-07-08T13:39:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3266&p=10925#p10925 <![CDATA[Uncia • Re: Uncia Hi performance system kit]]> Statistics: Posted by dangre — Wed Jul 08, 2015 1:39 pm
