Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-03-17T08:24:06-04:00 http://buildyourownsla.com/forum/feed.php?f=5&t=2786 2015-03-17T08:24:06-04:00 2015-03-17T08:24:06-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2786&p=8891#p8891 <![CDATA[Re: CW does not see the dlp projector resolution properly]]> It was because of display scaling in windows8. i am using a 4k main display and it is impossible to use it with windows standard scaling. Is there a workaround for this ? As turning off scaling, signing out each time I try a a print is not the best way to go :p.
Also great job for the software, it's pretty nice and reliable.
edit:
Found this also :). So all should be fine.
Disable DPI virtualization for the application. To do this, right-click the application’s shortcut and then click Properties. On the Compatibility tab, select Disable Display Scaling On High DPI Settings, and then click OK. This causes the text in the application to appear clearer. However, if the application does not correctly handle high DPI settings, this procedure may have adverse side effects such as truncated text and incorrectly sized graphical elements.
Statistics: Posted by aurelm — Tue Mar 17, 2015 8:24 am
2015-03-17T02:02:40-04:00 2015-03-17T02:02:40-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2786&p=8870#p8870 <![CDATA[Re: CW does not see the dlp projector resolution properly]]> Yes, in windows everything is ok. Actualy in CW all displays are misrepresented and the image is pixelated as if the internal frame buffer is much smaller.
Here:
Statistics: Posted by aurelm — Tue Mar 17, 2015 2:02 am
2015-03-16T21:45:10-04:00 2015-03-16T21:45:10-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2786&p=8867#p8867 <![CDATA[Re: CW does not see the dlp projector resolution properly]]> Statistics: Posted by PacManFan — Mon Mar 16, 2015 9:45 pm
2015-03-16T18:17:59-04:00 2015-03-16T18:17:59-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2786&p=8862#p8862 <![CDATA[CW does not see the dlp projector resolution properly]]> Statistics: Posted by aurelm — Mon Mar 16, 2015 6:17 pm
