Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-03-23T08:02:42-04:00 http://buildyourownsla.com/forum/feed.php?f=6&t=2040 2015-03-23T08:02:42-04:00 2015-03-23T08:02:42-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2040&p=9089#p9089 <![CDATA[Re: InFocus 2104]]>
I put in 3mm spacers to adjust the focal length and broke off the color wheel. However I also had a question as to what glass to remove since I wasn't getting any curing with 30 second exposures. After removing the glass right in front of the bulb on the bulb assembly, I was getting over-curing with 8 second exposures.
If I were to do it again I'd try just using zoom lenses over the projector lens to adjust the focal length and remove the glass from the bulb assembly – Just to see if the projector would work without having to crack it open. It took me much longer than I would have thought to do the mod. I ended up striping the projector down to the DLP chip and cleaned the entire optical path since I had dust splotches showing up in the projected image.
Statistics: Posted by miribota — Mon Mar 23, 2015 8:02 am
2014-09-29T11:36:41-04:00 2014-09-29T11:36:41-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2040&p=5480#p5480 <![CDATA[Re: InFocus 2104]]>
Do you have any photos?
They would be greatly appreciated.
Space......
EDIT:
So I got the focus/zoom assembly apart from the DLP chip housing. Now I see where you would put the spacer. Did you use 3mm arbitrarily? I was thinking 4mm or 5mm. Do you see a drawback to a spacer that big?
Also, you mentioned in your blog that you removed a 'suspicious' pane of glass that may be UV-resistant. I have 2 lenses and the angular mirror in the DLP housing. Was the lens you removed inside the DLP housing or elsewhere?
Thanks again for your help. Much appreciated.
Space....
Statistics: Posted by spaceman — Mon Sep 29, 2014 11:36 am
2014-09-29T10:47:28-04:00 2014-09-29T10:47:28-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2040&p=5479#p5479 <![CDATA[Re: InFocus 2104]]> Statistics: Posted by PacManFan — Mon Sep 29, 2014 10:47 am
2014-09-29T08:37:57-04:00 2014-09-29T08:37:57-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2040&p=5477#p5477 <![CDATA[Re: InFocus 2104]]> Statistics: Posted by spaceman — Mon Sep 29, 2014 8:37 am
2014-09-26T14:19:46-04:00 2014-09-26T14:19:46-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2040&p=5464#p5464 <![CDATA[Re: InFocus 2104]]> Statistics: Posted by PacManFan — Fri Sep 26, 2014 2:19 pm
2014-09-26T11:18:50-04:00 2014-09-26T11:18:50-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2040&p=5460#p5460 <![CDATA[InFocus 2104]]>
Does anyone use this projector? I wanted to know if I need to remove the color wheel? Has anyone changed the focal length on this unit?
Space...
Statistics: Posted by spaceman — Fri Sep 26, 2014 11:18 am
