Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-07-01T14:19:06-04:00 http://buildyourownsla.com/forum/feed.php?f=6&t=3230 2015-07-01T14:19:06-04:00 2015-07-01T14:19:06-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10791#p10791 <![CDATA[Re: Lead nut mounting]]> Section view of the mount:
There will be an interference between the linear bearing and the mount (around 0.5mm) to hold it in place... will it be enough?
This part will be printed in ABS plastic.
Statistics: Posted by avinash3333bhat — Wed Jul 01, 2015 2:19 pm
2015-07-01T11:05:15-04:00 2015-07-01T11:05:15-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10788#p10788 <![CDATA[Re: Lead nut mounting]]> Now you will need a mechanism to attach your nut assembly so it only moves in the z direction (linear slide, etc). As you have it now it will just rotate on the shaft until the build platform hits something. Also your shaft coupler will allow the shaft to spring up and down unless you have a rigid mount on the other end of the shaft (out of the picture?).
Statistics: Posted by dangre — Wed Jul 01, 2015 11:05 am
2015-07-01T10:30:24-04:00 2015-07-01T10:30:24-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10786#p10786 <![CDATA[Re: Lead nut mounting]]>
Statistics: Posted by avinash3333bhat — Wed Jul 01, 2015 10:30 am
2015-07-01T10:28:22-04:00 2015-07-01T10:28:22-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10785#p10785 <![CDATA[Re: Lead nut mounting]]>
The nut with the spring will be facing upwards...
Statistics: Posted by avinash3333bhat — Wed Jul 01, 2015 10:28 am
2015-06-30T15:16:21-04:00 2015-06-30T15:16:21-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10766#p10766 <![CDATA[Re: Lead nut mounting]]> Statistics: Posted by dangre — Tue Jun 30, 2015 3:16 pm
2015-06-30T15:02:07-04:00 2015-06-30T15:02:07-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10765#p10765 <![CDATA[Re: Lead nut mounting]]> Statistics: Posted by newraper1963 — Tue Jun 30, 2015 3:02 pm
2015-06-30T13:58:21-04:00 2015-06-30T13:58:21-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10764#p10764 <![CDATA[Re: Lead nut mounting]]> Statistics: Posted by sodium — Tue Jun 30, 2015 1:58 pm
2015-06-30T13:53:17-04:00 2015-06-30T13:53:17-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10763#p10763 <![CDATA[Re: Lead nut mounting]]>
Statistics: Posted by avinash3333bhat — Tue Jun 30, 2015 1:53 pm
2015-06-30T11:34:45-04:00 2015-06-30T11:34:45-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10761#p10761 <![CDATA[Re: Lead nut mounting]]> Statistics: Posted by newraper1963 — Tue Jun 30, 2015 11:34 am
2015-06-30T10:37:10-04:00 2015-06-30T10:37:10-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10759#p10759 <![CDATA[Re: Lead nut mounting]]> Statistics: Posted by sodium — Tue Jun 30, 2015 10:37 am
2015-06-30T10:29:10-04:00 2015-06-30T10:29:10-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3230&p=10758#p10758 <![CDATA[Lead nut mounting]]>
Please check out this lead nut block for top down sla printer.. It is used for M8 lead screw.. This part can be 3d printed.
Will this work? or any design changes required...It is used for Top down sla printer...
Statistics: Posted by avinash3333bhat — Tue Jun 30, 2015 10:29 am
