Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-08-09T04:32:16-04:00 http://buildyourownsla.com/forum/feed.php?f=6&t=3297 2015-08-09T04:32:16-04:00 2015-08-09T04:32:16-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=11652#p11652 <![CDATA[Re: Issue with the z-axis]]>
could you tell us about the m115 hd modification, i trying to bypass the blue led, did you change the blue leds for any uv luminus device? i got an custom uv led to exchange with original, now i having some troubles with electronics, couse when you take of the projectos protection, and rgb sensors seems to detect the missing stuff, would you share us your experience in m115hd modification? thanks
Statistics: Posted by 1125lbs — Sun Aug 09, 2015 4:32 am
2015-07-11T17:13:59-04:00 2015-07-11T17:13:59-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10995#p10995 <![CDATA[Re: Issue with the z-axis]]>
Statistics: Posted by mxmlan — Sat Jul 11, 2015 5:13 pm
2015-07-08T19:32:40-04:00 2015-07-08T19:32:40-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10931#p10931 <![CDATA[Re: Issue with the z-axis]]>
Statistics: Posted by mxmlan — Wed Jul 08, 2015 7:32 pm
2015-07-08T18:21:57-04:00 2015-07-08T18:21:57-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10930#p10930 <![CDATA[Re: Issue with the z-axis]]> Statistics: Posted by PacManFan — Wed Jul 08, 2015 6:21 pm
2015-07-08T16:26:27-04:00 2015-07-08T16:26:27-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10928#p10928 <![CDATA[Re: Issue with the z-axis]]> They are supposed to be the measured dimensions of the projected image, not the resolution of the projector.
Otherwise, maybe the ball is getting squashed somewhere in you software path?
Statistics: Posted by JohnGay — Wed Jul 08, 2015 4:26 pm
2015-07-08T15:06:14-04:00 2015-07-08T15:06:14-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10927#p10927 <![CDATA[Re: Issue with the z-axis]]> Statistics: Posted by mxmlan — Wed Jul 08, 2015 3:06 pm
2015-07-08T12:07:08-04:00 2015-07-08T12:07:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10922#p10922 <![CDATA[Re: Issue with the z-axis]]>
;(****Build and Slicing Parameters****)
;(Pix per mm X = 18.28571 px/mm )
;(Pix per mm Y = 18.28571 px/mm )
;(X Resolution = 1280 )
;(Y Resolution = 800 )
;(Layer Thickness = 0.10000 mm )
;(Layer Time = 15000 ms )
;(Render Outlines = False
;(Outline Width Inset = 2
;(Outline Width Outset = 0
;(Bottom Layers Time = 25000 ms )
;(Number of Bottom Layers = 3 )
;(Blanking Layer Time = 10600 ms )
;(Build Direction = Bottom_Up)
;(Lift Distance = 5 mm )
;(Slide/Tilt Value = 0)
;(Anti Aliasing = False)
;(Use Mainlift GCode Tab = False)
;(Anti Aliasing Value = 1.5 )
;(Z Lift Feed Rate = 50.00000 mm/s )
;(Z Bottom Lift Feed Rate = 25.00000 mm/s )
;(Z Lift Retract Rate = 100.00000 mm/s )
;(Flip X = True)
;(Flip Y = True)
;Number of Slices = 392
;(****Machine Configuration ******)
;(Platform X Size = 70mm )
;(Platform Y Size = 43.75mm )
;(Platform Z Size = 200mm )
;(Max X Feedrate = 100mm/s )
;(Max Y Feedrate = 100mm/s )
;(Max Z Feedrate = 100mm/s )
;(Machine Type = UV_DLP)
;********** Header Start ********
;Here you can set any G or M-Code which should be executed BEFORE the build process
G21 ;Set units to be mm
G91 ;Relative Positioning
M17 ;Enable motors
;********** Header End **********
;********** Pre-Slice Start ********
;Set up any GCode here to be executed before a lift
;********** Pre-Slice End **********
;<Slice> 0
;<Delay> 25000
;<Slice> Blank
G1 Z5.0 F25.0
G1 Z-4.9 F100.0
;<Delay> 10600
;<Slice> 1
;<Delay> 25000
;<Slice> Blank
G1 Z5.0 F25.0
G1 Z-4.9 F100.0
;<Delay> 10600
Statistics: Posted by mxmlan — Wed Jul 08, 2015 12:07 pm
2015-07-08T11:57:29-04:00 2015-07-08T11:57:29-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=3297&p=10919#p10919 <![CDATA[Issue with the z-axis]]>
I recently finished my printer but I still have some issues with the z-axis. All my prints are out of shape on the z-axis. I'm using a Dell M115 HD, Ramps 1.4, Pololu stepper driver, Nema 23 stepper motor (http://en.nanotec.com/fileadmin/files/D ... 1008-A.pdf), 16mm Rod (4mm pitch per rotation) and 1/16 micro stepping with configured 800 steps per unit with the modified mUVe firmware. Does anyone have a clue for me?
Layer height: 0.1mm
First layer time: 20 sec.
Layer time: 15 sec. (the projector has just 450 Lumen)
There is no wobbling on z. There seem to be no problem if I move z manually. :cry:
What do you think?
Thank you so much!
And please just ignore the cracks on the base plate.
Statistics: Posted by mxmlan — Wed Jul 08, 2015 11:57 am
