Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2014-03-05T12:27:25-04:00 http://buildyourownsla.com/forum/feed.php?f=6&t=525 2014-03-05T12:27:25-04:00 2014-03-05T12:27:25-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=525&p=1853#p1853 <![CDATA[Re: hardware design questions]]> Statistics: Posted by Finhead — Wed Mar 05, 2014 12:27 pm
2014-03-05T12:11:52-04:00 2014-03-05T12:11:52-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=525&p=1852#p1852 <![CDATA[Re: hardware design questions]]> Statistics: Posted by IrgendwerAusIrgendwo — Wed Mar 05, 2014 12:11 pm
2014-03-05T11:48:10-04:00 2014-03-05T11:48:10-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=525&p=1850#p1850 <![CDATA[Re: hardware design questions]]> Statistics: Posted by Finhead — Wed Mar 05, 2014 11:48 am
2014-03-05T07:18:02-04:00 2014-03-05T07:18:02-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=525&p=1841#p1841 <![CDATA[hardware design questions]]>
I'm currently on the way to design a rigid machine base and as I want everything perfect on my digital model I got some questions regarding dimension- I don't want to buy a projector before beeing sure that everything is as I want it to be. ;-)
1.) dimension
On this site the focus of the machine at 100x100mm is around 250mm:
http://www.instructables.com/id/DIY-hig ... r/?lang=de
In my eyes I should switch my projector at highest resolution (1920*1080) and measure the distance so that the projected image has 192*108mm: I would to this on both dead centers of the focus to find the mid-position.
To change dimension and focus on the machine hardware I would make the plate hight-adjustable (app +-30mm).
2.) What type of endstop do you use?
When printing at e.g. 0,03mm layer hight you'll need a VERY good endstop.
As far as I have seen now (I'm developing a lot at RepRap 3D printers) simple switches, opto endstops and Hall-sensors are very common - which one would you prefer?
3.) linear motion
Most of the self built machines and even the commercial machines use dovetail guides. As I want to create my machine open, cheap and buildable by everyone I'm planning to use 16mm rods and fixed guides on top and bottom!?
4.) printbed size
As mentioned I plan to have a printbed of 192*108mm (resolution therefore 0,1mm): has anybody got experience with moving the projector + mirror so that you have e.g. 3 steps of the 108mm side and therefore 192 * (108*3) mm?
Statistics: Posted by IrgendwerAusIrgendwo — Wed Mar 05, 2014 7:18 am
