Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-08-20T12:16:11-04:00 http://buildyourownsla.com/forum/feed.php?f=8&t=1529 2015-08-20T12:16:11-04:00 2015-08-20T12:16:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=11909#p11909 <![CDATA[Re: my DLP build]]> this is my plate compilation created for Atum 3d. ;) ;)
Statistics: Posted by seblos — Thu Aug 20, 2015 12:16 pm
2015-07-19T18:46:16-04:00 2015-07-19T18:46:16-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=11171#p11171 <![CDATA[Re: my DLP build]]> congratulation about the prints!
i'm from turin too! where did you get your first surface mirror and the build platform? how much do they cost?
thank you
Statistics: Posted by sley — Sun Jul 19, 2015 6:46 pm
2015-07-17T11:08:32-04:00 2015-07-17T11:08:32-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=11148#p11148 <![CDATA[Re: my DLP build]]> Statistics: Posted by willve — Fri Jul 17, 2015 11:08 am
2015-06-27T05:30:16-04:00 2015-06-27T05:30:16-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=10697#p10697 <![CDATA[Re: my DLP build]]> Statistics: Posted by hp_ — Sat Jun 27, 2015 5:30 am
2015-06-27T05:17:01-04:00 2015-06-27T05:17:01-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=10696#p10696 <![CDATA[Re: my DLP build]]> Statistics: Posted by educa — Sat Jun 27, 2015 5:17 am
2015-02-22T14:59:52-04:00 2015-02-22T14:59:52-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=8482#p8482 <![CDATA[Re: my DLP build]]> Statistics: Posted by hp_ — Sun Feb 22, 2015 2:59 pm
2015-02-22T12:42:43-04:00 2015-02-22T12:42:43-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=8478#p8478 <![CDATA[Re: my DLP build]]>
Statistics: Posted by sodium — Sun Feb 22, 2015 12:42 pm
2015-01-02T15:04:46-04:00 2015-01-02T15:04:46-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=7270#p7270 <![CDATA[Re: my DLP build]]>
i think you will notice when using Creation workshop the results will be stunning.
here is a print on 0.1mm
0.1 layer height
150 mm/min up
6mm retract length
650 mm/min down
Statistics: Posted by hp_ — Fri Jan 02, 2015 3:04 pm
2015-01-02T10:20:58-04:00 2015-01-02T10:20:58-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=7267#p7267 <![CDATA[Re: my DLP build]]> Statistics: Posted by sodium — Fri Jan 02, 2015 10:20 am
2015-01-01T17:59:45-04:00 2015-01-01T17:59:45-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=7252#p7252 <![CDATA[Re: my DLP build]]> Statistics: Posted by hp_ — Thu Jan 01, 2015 5:59 pm
2015-01-01T11:17:52-04:00 2015-01-01T11:17:52-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=7249#p7249 <![CDATA[Re: my DLP build]]>
been struggling this morning and decided to check tension of the fep.. saw it was not stretched enough. fixed the problem.. and again.. printing with no issue :)
the more strechted and tensed the fep film is the easier it is to print with it.
Statistics: Posted by hp_ — Thu Jan 01, 2015 11:17 am
2014-08-29T13:17:07-04:00 2014-08-29T13:17:07-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=4810#p4810 <![CDATA[Re: my DLP build]]>
i can confirm 50micron is also not a problem. i print this thickness all the time now.
25 micron i also tried and it printed but i made a mistake and let my vat run dry :)
be-aware i use a special VAT construction that makes this possible.. very low pull force needed :)
Statistics: Posted by hp_ — Fri Aug 29, 2014 1:17 pm
2014-08-29T13:01:53-04:00 2014-08-29T13:01:53-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=4807#p4807 <![CDATA[Re: my DLP build]]>
Hp, do you think that belt driven Z axis can do 25 and 50 micron layer thickness!
If it can do so, I would say it will be a great option to consider, since it's faster and quieter than a lead screw. Have you done any experimentation with those thicknesses?
Statistics: Posted by anthony.julu — Fri Aug 29, 2014 1:01 pm
2014-08-21T21:50:56-04:00 2014-08-21T21:50:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=4685#p4685 <![CDATA[Re: my DLP build]]> How are you peeling the print? It looks like your using a pillow vat, could you explain it a bit? It seems quite complicated...
Thanks,
Michael
Statistics: Posted by MichaelD33 — Thu Aug 21, 2014 9:50 pm
2014-07-26T16:32:40-04:00 2014-07-26T16:32:40-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1529&p=4363#p4363 <![CDATA[Re: my DLP build]]>
i've measured 1.5mm so i guess average.. 1.5 - 2mm
Statistics: Posted by hp_ — Sat Jul 26, 2014 4:32 pm
