Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2016-01-12T12:01:30-04:00 http://buildyourownsla.com/forum/feed.php?f=8&t=1725 2016-01-12T12:01:30-04:00 2016-01-12T12:01:30-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1725&p=14038#p14038 <![CDATA[Re: SLA printer build]]> printerhttp://es.aliexpress.com/item/Ho ... 264.bXTEme
Statistics: Posted by jose — Tue Jan 12, 2016 12:01 pm
2015-07-09T06:49:25-04:00 2015-07-09T06:49:25-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1725&p=10951#p10951 <![CDATA[Re: SLA printer build]]> Regards
Drago
Statistics: Posted by dragokirov — Thu Jul 09, 2015 6:49 am
2015-07-09T06:04:34-04:00 2015-07-09T06:04:34-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1725&p=10948#p10948 <![CDATA[Re: SLA printer build]]>
Could you please elaborate more on how the mirror can be used to adjust distortion?
D.
Statistics: Posted by danielm — Thu Jul 09, 2015 6:04 am
2015-07-09T04:22:22-04:00 2015-07-09T04:22:22-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1725&p=10947#p10947 <![CDATA[Re: SLA printer build]]> Good job! I have a question. Why you do not use a mirror to adjust the distortion and to save a space? I think it's better. I use an adjustable mirror and two sliders.
Drago
Statistics: Posted by dragokirov — Thu Jul 09, 2015 4:22 am
2015-07-09T02:58:45-04:00 2015-07-09T02:58:45-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1725&p=10943#p10943 <![CDATA[Re: SLA printer build]]>
And this is one of first test objects - not very clean, but it works:
Next steps are experiments with VAT using Drago's sheet and improvements on the SW side.
Statistics: Posted by danielm — Thu Jul 09, 2015 2:58 am
2014-09-09T05:22:12-04:00 2014-09-09T05:22:12-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1725&p=4967#p4967 <![CDATA[SLA printer build]]>
Top section of the frame was equiped with Z-axis linear guides and ball spindles on both left and tight side. It is currently driven by single timing belt, however I am considering to drive both sides with dedicated steppers and perform peel action by independent movement of Z-right and Z-left.
In the bottom section there is Lasershark-based "laser projector" mounted on an extrusion profile:
Z-axis electronics is missing - I have Megatronics v3 prepared on my table.
Build platform is missing as well - it will be mounted on the extrusion connected to linear carriages.
I only have small VAT from Pryntech kit available at the moment: http://pryntech.com/?product=optically- ... crylic-vat
I will build larger VAT later.
What kind of VAT construcion and peeling mechanism would you recommend?
Statistics: Posted by danielm — Tue Sep 09, 2014 5:22 am
