Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-05-29T12:40:31-04:00 http://buildyourownsla.com/forum/feed.php?f=8&t=2958 2015-05-29T12:40:31-04:00 2015-05-29T12:40:31-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=10210#p10210 <![CDATA[Re: Build started finally]]> im in the process to implement mine in the acer 6510. without mask, i think it will be impossible to use the entire build plate at once.
Statistics: Posted by sodium — Fri May 29, 2015 12:40 pm
2015-05-29T05:33:14-04:00 2015-05-29T05:33:14-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=10199#p10199 <![CDATA[Re: Build started finally]]>
Statistics: Posted by nc42 — Fri May 29, 2015 5:33 am
2015-05-29T05:29:13-04:00 2015-05-29T05:29:13-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=10198#p10198 <![CDATA[Re: Build started finally]]>
A few more details:
In a flex vat this big, 210 x 260 there is quite a bit of load! I had to reinforce the bottom plate going from 3mm carbon plate to 6mm. Also have had some issues with the FEP ripping on the corners of the vat walls. Overall though I'm happy with my vat design where the vat walls push down into the film to create tension.
I used slot nuts in the extrusion from mounting the projector that have set screws to hold them in place. This way I can have multiple sets and be able to record the resolution settings for the different sets making it easy to change.
Statistics: Posted by nc42 — Fri May 29, 2015 5:29 am
2015-05-08T07:28:24-04:00 2015-05-08T07:28:24-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=9887#p9887 <![CDATA[Re: Build started finally]]> Statistics: Posted by nc42 — Fri May 08, 2015 7:28 am
2015-05-08T05:25:27-04:00 2015-05-08T05:25:27-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=9884#p9884 <![CDATA[Re: Build started finally]]> carbon fiber are so cool :shock:
Statistics: Posted by sodium — Fri May 08, 2015 5:25 am
2015-05-07T19:18:56-04:00 2015-05-07T19:18:56-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=9880#p9880 <![CDATA[Re: Build started finally]]>
Statistics: Posted by nc42 — Thu May 07, 2015 7:18 pm
2015-05-07T02:02:02-04:00 2015-05-07T02:02:02-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=9861#p9861 <![CDATA[Re: Build started finally]]>
Statistics: Posted by nc42 — Thu May 07, 2015 2:02 am
2015-05-07T01:54:16-04:00 2015-05-07T01:54:16-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=9860#p9860 <![CDATA[Re: Build started finally]]>
Statistics: Posted by nc42 — Thu May 07, 2015 1:54 am
2015-05-07T05:00:45-04:00 2015-05-07T01:47:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2958&p=9859#p9859 <![CDATA[Build started finally]]>
Build details:
Bottom up
Z-axis: 300mm of travel THK linear slide bought off ebay new for $150
Vat: Flex vat where the vat walls push down into the film to tension it. Idea is to allow use with projector or LCD
Projector: Acer H6B510BD but will play with LCD options
Ball head to level build plate to vat bottom
Build some parts out of carbon fiber due to free time and supplies at work. Vat walls, platform bracket, shutter and z-axis motor adapter
Statistics: Posted by nc42 — Thu May 07, 2015 1:47 am
