Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-03-04T16:46:09-04:00 http://buildyourownsla.com/forum/feed.php?f=9&t=1702 2015-03-04T16:46:09-04:00 2015-03-04T16:46:09-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=8671#p8671 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
Statistics: Posted by kakapoopie — Wed Mar 04, 2015 4:46 pm
2014-12-05T18:56:29-04:00 2014-12-05T18:56:29-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=6511#p6511 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
Statistics: Posted by kakapoopie — Fri Dec 05, 2014 6:56 pm
2014-10-09T20:11:47-04:00 2014-10-09T20:11:47-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=5582#p5582 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> This time my own design which can be seen here
Statistics: Posted by kakapoopie — Thu Oct 09, 2014 8:11 pm
2014-09-26T12:08:43-04:00 2014-09-26T12:08:43-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=5462#p5462 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> Statistics: Posted by Happycamper — Fri Sep 26, 2014 12:08 pm
2014-09-25T19:00:55-04:00 2014-09-25T19:00:55-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=5454#p5454 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> Statistics: Posted by kakapoopie — Thu Sep 25, 2014 7:00 pm
2014-09-25T15:25:18-04:00 2014-09-25T15:25:18-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=5452#p5452 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> What resin are you using now and what exposure are you using?
Statistics: Posted by dangre — Thu Sep 25, 2014 3:25 pm
2014-09-25T14:53:08-04:00 2014-09-25T14:53:08-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=5451#p5451 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
Statistics: Posted by kakapoopie — Thu Sep 25, 2014 2:53 pm
2014-09-09T14:12:57-04:00 2014-09-09T14:12:57-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4980#p4980 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
Statistics: Posted by kakapoopie — Tue Sep 09, 2014 2:12 pm
2014-09-05T16:47:55-04:00 2014-09-05T16:47:55-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4923#p4923 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> Statistics: Posted by kakapoopie — Fri Sep 05, 2014 4:47 pm
2014-09-02T16:12:53-04:00 2014-09-02T16:12:53-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4877#p4877 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> Statistics: Posted by kakapoopie — Tue Sep 02, 2014 4:12 pm
2014-09-02T15:12:47-04:00 2014-09-02T15:12:47-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4874#p4874 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
I have order some funtodo industrial and will not print again until it arrives.
Also with the top down I noticed it is all about having a level build plate. Wasted hours with problems from this. Much more forgiving when supports are used to get away from the build plate and start wider slices.
Statistics: Posted by Magnitude — Tue Sep 02, 2014 3:12 pm
2014-09-01T19:18:44-04:00 2014-09-01T19:18:44-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4866#p4866 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
Statistics: Posted by kakapoopie — Mon Sep 01, 2014 7:18 pm
2014-08-30T02:03:46-04:00 2014-08-30T02:03:46-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4832#p4832 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
@Steve: you used 500ms curing time and still see bleed through? How fast is the resin, really?
I will be using a Benq CP220 (XGA, 190watt power), and would like to print at 50microns with SG+, and at 25microns with his castable resin. I sure hope that I will not encounter this similar problem. Especially with the castable resin, which I plan to use to capture some really fine details to produce models to be processed with lost-wax casting.
I need to know how to make my donation by bank transfer/Western Union, can someone tell me how?
Statistics: Posted by anthony.julu — Sat Aug 30, 2014 2:03 am
2014-08-25T18:35:41-04:00 2014-08-25T18:35:41-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4745#p4745 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]>
Statistics: Posted by kakapoopie — Mon Aug 25, 2014 6:35 pm
2014-08-25T15:19:38-04:00 2014-08-25T15:19:38-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=1702&p=4737#p4737 <![CDATA[Re: Print Tests, SubG+ Heavy earthquake sculpture]]> -Steve
Statistics: Posted by PacManFan — Mon Aug 25, 2014 3:19 pm
