Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-01-30T16:21:25-04:00 http://buildyourownsla.com/forum/feed.php?f=9&t=2624 2015-01-30T16:21:25-04:00 2015-01-30T16:21:25-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2624&p=8023#p8023 <![CDATA[Re: Weird print]]>
Statistics: Posted by Matze — Fri Jan 30, 2015 4:21 pm
2015-01-30T05:12:45-04:00 2015-01-30T05:12:45-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2624&p=8013#p8013 <![CDATA[Re: Weird print]]>
@Scatterplot: The part should have been straight. All the little parts shouldn't be there.
@Phife: I checked the vat and there where no resin pieces floating around. I saw some little metal flake (I'd guess from filing/sanding the build platform). Maybe that was the reason. I'll redo the print with a clean vat.
Other than that I used Makerjuice SF (white), a FlexVat with 0.1mm PTFE film. 5 sec curing time with z = 0.2mm. Small parts worked great so far... About the build plattform you can see more details here: it's 2mm stainless steel with 3mm holes in it. After sanding it the parts stick quiet well and also the pressure to the PTFE film is minimized (no deformation while printing the first couple of layers)
Statistics: Posted by Matze — Fri Jan 30, 2015 5:12 am
2015-01-29T18:35:36-04:00 2015-01-29T18:35:36-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2624&p=8008#p8008 <![CDATA[Re: Weird print]]>
Have you tried printing other parts? What kind of vat/release method are you using? What kind of resin is that.
Oh and your build plate looks interesting, what is that?
Statistics: Posted by Phife — Thu Jan 29, 2015 6:35 pm
2015-01-29T16:27:33-04:00 2015-01-29T16:27:33-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2624&p=8006#p8006 <![CDATA[Re: Weird print]]> Statistics: Posted by Scatterplot — Thu Jan 29, 2015 4:27 pm
2015-01-29T15:23:07-04:00 2015-01-29T15:23:07-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2624&p=8003#p8003 <![CDATA[Weird print]]>
I just printed a big part (10x5x15cm) for the first time and I got weird errors:
Does anyone has a clue what went wrong?
Thanks and best regards,
Matthias
Statistics: Posted by Matze — Thu Jan 29, 2015 3:23 pm
