Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-02-26T02:35:11-04:00 http://buildyourownsla.com/forum/feed.php?f=9&t=2681 2015-02-26T02:35:11-04:00 2015-02-26T02:35:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8554#p8554 <![CDATA[Re: Water clear print]]>
its the b9 water clear from venus creator.
Statistics: Posted by hp_ — Thu Feb 26, 2015 2:35 am
2015-02-25T19:02:06-04:00 2015-02-25T19:02:06-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8546#p8546 <![CDATA[Re: Water clear print]]> Statistics: Posted by jkao — Wed Feb 25, 2015 7:02 pm
2015-02-15T14:55:02-04:00 2015-02-15T14:55:02-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8320#p8320 <![CDATA[Re: Water clear print]]>
layer height should be set to 0.05mm though.. per layer..
Statistics: Posted by hp_ — Sun Feb 15, 2015 2:55 pm
2015-02-15T14:43:30-04:00 2015-02-15T14:43:30-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8319#p8319 <![CDATA[Re: Water clear print]]> Mine was printed with acer p1500 with ptfe flex vat.
Statistics: Posted by how_eee — Sun Feb 15, 2015 2:43 pm
2015-02-15T14:37:27-04:00 2015-02-15T14:37:27-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8318#p8318 <![CDATA[Re: Water clear print]]>
actually it was an trail and error, with exposure times en light intensity.
got the water clear printing pretty well now.
although this is a failed print(leak in the flex vat)
i found it nice enough to post
Statistics: Posted by hp_ — Sun Feb 15, 2015 2:37 pm
2015-02-15T11:26:11-04:00 2015-02-15T11:26:11-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8315#p8315 <![CDATA[Re: Water clear print]]> what tweak of projector you made?
here is my best result. same resin with and without pigment. layer time 400ms and 300ms.
with less time print will be broken
what tweak of projector did you make?
Statistics: Posted by how_eee — Sun Feb 15, 2015 11:26 am
2015-02-15T08:00:53-04:00 2015-02-15T08:00:53-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2681&p=8314#p8314 <![CDATA[Water clear print]]>
i've been experimenting with some water clear resins, what i've found out is they are extremely hard to print with normal off the shelve projectors.
tweaking my current setup with a custom projector produced these 2 lovely ear buds.
layer thickness = 0.05mm
exposure time = 4.8 sec per layer.
intensity set to 102% on my projector
pull up speed 50
down speed 650
vat - flex vat
Statistics: Posted by hp_ — Sun Feb 15, 2015 8:00 am
