Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-03-23T08:11:28-04:00 http://buildyourownsla.com/forum/feed.php?f=9&t=2800 2015-03-23T08:11:28-04:00 2015-03-23T08:11:28-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9091#p9091 <![CDATA[Re: Top-Down Resing floating on salt water]]> I'll test them as soon as I can :D
Statistics: Posted by odino — Mon Mar 23, 2015 8:11 am
2015-03-20T16:17:19-04:00 2015-03-20T16:17:19-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9043#p9043 <![CDATA[Re: Top-Down Resing floating on salt water]]> Statistics: Posted by Zenon — Fri Mar 20, 2015 4:17 pm
2015-03-20T14:27:20-04:00 2015-03-20T14:27:20-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9038#p9038 <![CDATA[Re: Top-Down Resing floating on salt water]]> Here ya go...
http://www.thingiverse.com/thing:732652
Dan
Statistics: Posted by dangre — Fri Mar 20, 2015 2:27 pm
2015-03-20T10:55:13-04:00 2015-03-20T10:55:13-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9034#p9034 <![CDATA[Re: Top-Down Resing floating on salt water]]>
What model are you talking? Have you some link to share?
I have something from when I calibrate my prusa I3.
I have wrote a note to FTD and they told me that the temperature of the room (my labs has a temperature of 10-12° celsius) is to low. The resin should be at 18-22° celsius to have a better performance...
I'm out for the weekend, but next week I'll come back to work :)
If you have share the test model or the link please :D
Statistics: Posted by odino — Fri Mar 20, 2015 10:55 am
2015-03-20T09:05:03-04:00 2015-03-20T09:05:03-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9032#p9032 <![CDATA[Re: Top-Down Resing floating on salt water]]> If I might make a suggestion, try printing one of the calibration models out there that have different size (small) posts so you can calibrate your machine. Try lots of different settings (3-4-5-6+sec) so you know where your boundaries are. Otherwise you are just guessing. Then you can try adding pigments etc. Make sure you write down your findings and take pictures.
Statistics: Posted by dangre — Fri Mar 20, 2015 9:05 am
2015-03-19T18:49:28-04:00 2015-03-19T18:49:28-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9015#p9015 <![CDATA[Re: Top-Down Resing floating on salt water]]> And it come out well!
I think the curing time is good. Maybe a little of z-wobble...
Well I have to keep trying :D
I was wondering if I could increase the red-pigment quatity (or add some black/dark pigment) to shield some of the rays so I could increase the curing time without have much problem...
Statistics: Posted by odino — Thu Mar 19, 2015 6:49 pm
2015-03-19T18:45:51-04:00 2015-03-19T18:45:51-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=9014#p9014 <![CDATA[Re: Top-Down Resing floating on salt water]]> I have done another 0.05mm plate.
2 rings and 2 of this statue
the statue come out quite well...
The sword end collapse... If think it was too tiny... the entire statue is about 3cm...
the rings on the contrary have come major issue...
the tiny part of the rings don't come out again... the supports are fine...
The surface is nice but... well it's not complete...
I think 3 seconds are to low again... but I'm afraid that if I increase more I'll have overcuring problem...
Maybe the translucence of the resin is a problem...
Statistics: Posted by odino — Thu Mar 19, 2015 6:45 pm
2015-03-19T08:21:05-04:00 2015-03-19T08:21:05-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=2800&p=8978#p8978 <![CDATA[Top-Down Resing floating on salt water]]> And now I'm doing some pretty prints.
Not perfect yet, but pretty.
This was done yesterday
First decent print afeter a simple cube :D
I want to go under so today I have cut in half the exposition time and try to print the same object.
In the plate there was 2 rings and 2 little owls (to see if the plate was really flat).
The owls come out really nice!
The rings on the contrary come out really bad...
The little support collapse on themself, like the tiny parts of the rings.
I suppose low exposition time, so I increase it to 3 sec now, and try to reprint the rings with some other object, a model take from thingiverse to compare the rings with a more massive items.
I'll post other photo as soon I can!
Advice or criticism are always welcome :D
Statistics: Posted by odino — Thu Mar 19, 2015 8:21 am
