Build Your Own SLA/SLS A forum dedicated to helping you build your own SLA/SLS-based 3d printer 2015-10-09T00:56:12-04:00 http://buildyourownsla.com/forum/feed.php?f=9&t=4233 2015-10-09T00:56:12-04:00 2015-10-09T00:56:12-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4233&p=12910#p12910 <![CDATA[Re: weird surface finish - flakes every where]]> Statistics: Posted by James — Fri Oct 09, 2015 12:56 am
2015-10-07T18:31:24-04:00 2015-10-07T18:31:24-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4233&p=12856#p12856 <![CDATA[Re: weird surface finish - flakes every where]]> Statistics: Posted by crusoe — Wed Oct 07, 2015 6:31 pm
2015-10-06T16:25:19-04:00 2015-10-06T16:25:19-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4233&p=12818#p12818 <![CDATA[Re: weird surface finish - flakes every where]]> Statistics: Posted by claudio.reyes — Tue Oct 06, 2015 4:25 pm
2015-10-06T16:24:04-04:00 2015-10-06T16:24:04-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4233&p=12817#p12817 <![CDATA[Re: weird surface finish - flakes every where]]>
https://groups.google.com/forum/#!forum/fsl3d
Statistics: Posted by sodium — Tue Oct 06, 2015 4:24 pm
2015-10-06T13:34:18-04:00 2015-10-06T13:34:18-04:00 http://buildyourownsla.com/forum/viewtopic.php?t=4233&p=12814#p12814 <![CDATA[weird surface finish - flakes every where]]> On first place I thougt was a optical problem so I perfectly cleaned the galvo mirros and the 45° one.
Recalibrated galvos and laser (build extends, laser extends and dot layout).
Tested again with same results.
An odd fact is that the firsts layer comes very fine.
All resins used for the test were from new bottles and well mixed before print.
The printer was turned off for about 1.5-2 months.
When opened retina software I performed the last upgrade. Also I noticed that there is a galvo test, how this test should be performed?
Attached is a pdf with example images.
Any help or work around will be appreciated I have a print order that I need to deliver ASAP.
Weird Surface quality.pdf
Statistics: Posted by claudio.reyes — Tue Oct 06, 2015 1:34 pm
