.. i only can se small objekt like 2x2x2cm to maybe 10x10x10, is it possible to print out larger objects like 30x30x30 or even bigger if the vat can contain that volume of resin?
thanks for reply.
how big can the object be..?
Re: how big can the object be..?
There isn't a limit to how big an object can be in Creation workshop. You'll just need to set up the build area correctly.
Excited4DLP
- Joined: Wed May 14, 2014 10:40 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Is it even physically possible to print something as big as 12" x 12" with a DLP/SLA printer seeing that the Van Der Waal force is almost 200lbs with a 7.5" x 4.25" build plate?
Excited4DLP
Excited4DLP
I noticed that the Titan 1 from Kudo uses some sort of flexible material for their VAT while allows the entire VAT to "peel" from the build plate when the Z-axis moves upward. What type of material is flexible that is also thick enough to be used as a VAT that lets UV light pass through?
