Any of you had any incident with the backlight of the projector.
I am using resin fun2do brand and always get similar results. backlight on projector cure thin layers of resin and everything breaks down.
I have adjusted the projector settings to hiest contrast and lowest brightnes, but I still have problems.
any recommendations will be welcome. thank you very much.
Backlight projector problems.
firecardenal
firecardenal
Re: Backlight projector problems.
Solved!!!
I bought a variable Neutral Density filter and install to the projector lens.
So i can turn more or less bright, depend on the resin sensibility.
But dont install close to the projector lens or will burn the filter.
SlowSL
- Joined: Thu Mar 31, 2016 9:36 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Glad you fixed it. I will just throw this out there in case anyone has the problem that I did. I let the projector auto-adjust when I first got it. For some reason the brightness was cranked up to 93%. I manually lowered it to 30% and all was good after that.
