Backlight projector problems.
Posted: Fri Apr 08, 2016 7:07 pm
by firecardenal
Any of you had any incident with the backlight of the projector.
I am using resin fun2do brand and always get similar results. backlight on projector cure thin layers of resin and everything breaks down.
I have adjusted the projector settings to hiest contrast and lowest brightnes, but I still have problems.
any recommendations will be welcome. thank you very much.
Re: Backlight projector problems.
Posted: Sat Apr 16, 2016 4:32 pm
by firecardenal
Solved!!!
I bought a variable Neutral Density filter and install to the projector lens.
So i can turn more or less bright, depend on the resin sensibility.
But dont install close to the projector lens or will burn the filter.
Posted: Wed Apr 20, 2016 3:40 pm
by SlowSL
Glad you fixed it. I will just throw this out there in case anyone has the problem that I did. I let the projector auto-adjust when I first got it. For some reason the brightness was cranked up to 93%. I manually lowered it to 30% and all was good after that.
