@ Hugues
If you are able to order 20Kg or more at a time or cover a day or two of formulation time we can blend resins to your specs
http://bucktownpolymers.com/services.html
Any resins strong enough for engineering purpose ?
Cation
Re: Any resins strong enough for engineering purpose ?
ABS types are not a problem. The problem you are starting out with is using bottom up projection through a vat and peeling every layer along with using UV. This limits the viscosity, solids content and curing rate of the resins and composites as well as curing depth.
There is a project that is using SLA to print laptop and cellphone cases using similar resins. These resins might become standard products in the near future.
