take a look at this post:
Also, you may want to try this utility for exposure testing:
Makerjuice Waxcast.
Re: Makerjuice Waxcast.
Research Chemist
hirenashra
hirenashra
chill74
- Joined: Tue Jun 16, 2015 3:09 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
No, the shrinkage might be 0.5% or so. If your print is that much smaller, it means you need to calibrate your print software. Do you use CW?
hirenashra
