Page 1 of 6
Resins For Investment Casting
Posted: Sat Mar 29, 2014 11:30 am
by James
Post any that you run into.
Here's one that will be available by May of this year.
Re: Resins For Investment Casting
Posted: Sat Mar 29, 2014 1:50 pm
by hp_
hi James,
$200 my gosh thats expensive..
better go with Spota resin - castable - 45 Euro for 500mL...
HP
Posted: Sat Mar 29, 2014 2:59 pm
by seblos
Give me the link of spot-on for castable resin,
thanks
Posted: Sat Mar 29, 2014 3:26 pm
by James
Hi HP!
Hmmm... I looked all around their website and couldn't find anything like that. They do have one under development, , but they've had that under development for several months now.
I'm all for less expensive though!
Posted: Sat Mar 29, 2014 4:22 pm
by hp_
ahh sorry guys.. fernando gave that link personally... i can't distribute..
but i'm sure this resin will become available very soon...
Posted: Sun Mar 30, 2014 4:42 pm
by johnrpm
SLA systems use a build style called quickcast, its honeycombed, I mentioned somewhere in another post that it may be possible to
do the same with a form of dithering or image processing?.
The casting firm need experiance with it, as its different to wax.
Posted: Mon Mar 31, 2014 10:35 pm
by Glacian22
I'm surprised no one has mentioned B9Creator's B9R-Red. It's marketed specifically for casting, after all.
http://b9creator.com/product/b9r-1-red- ... g-2-2-lbs/
Posted: Mon Mar 31, 2014 10:44 pm
by James
Oh! Ok. Good to know. I knew Mike sent some samples out for casting back when he was doing his kickstarter campaign, but I didn't know he ended up marketing it as such. I'll most definitely try this out once I'm up and running. Thanks!
Posted: Tue Apr 01, 2014 3:33 am
by hp_
Makerjuice is also testing with castable resin. we would be great if we get more resin suppliers on the market
Posted: Thu Apr 30, 2015 11:59 pm
by Cation
Bucktown Polymers has a new rinse out resin for investment casting. It does not burn out or melt out. It is rinsed out with hot water.
After the cured polymer or rinse out resin (ROR) is coated with the investment and left to dry for two hours the investment is soaked in hot water for 1-2 hours to allow the resin to dissolve. The investment green strength is strong enough to hold up to hot water rinse out or even steam rinse. The investment just needs to dry for a few minutes before being placed in the oven for firing.
