Page 1 of 2
Formulas for home brewed photosensitive resins.
Posted: Thu May 08, 2014 11:26 pm
by seasicksinbad
I thought it might be interesting to start a thread on formulas for photosensitive resins.
I remember years ago I experimented a bit on the subject, creating a very simple yet practical UV sensitive resin mixing Polyester resin with Potassium Dichromate.
Potassium Dichromate is a very powerful oxidizer and must be treated with respect.
I believe I dissolved it first with alcohol and then I mixed it with the Polyester resin.
Re: Formulas for home brewed photosensitive resins.
Posted: Fri May 09, 2014 4:49 am
by @A2
I would like to see the development of a vegitable based UV resin. The following papers indicate that it's possible, or offer introductions to the topic.
A Fully Biobased Epoxy Resin from Vegetable Oils: From the Synthesis of the Precursors by Thiol-ene Reaction to the Study of the Final MaterialMarch 2011
Grapeseed oil
In this article, we describe the functionalization of grapeseed oil (GSO) with amine groups involving the thiol-ene reaction.
This article developed the scientific methodology used to produce a polyamine from an unsaturated vegetable oil using the reaction of cysteamine chloride and UV-initiated thiolene chemistry.
Thus, we present here a new concept for the synthesis of polyamine based on unsaturated triglycerides thanks to the thiol-ene reaction.
... click-chemistry concept. This simple reaction is very attractive due to its simple processing despite
unpleasant odor of mercaptans. It can be performed under thermal initiation or UV light irradiation with higher reaction rates.
In this context, thiol-ene chemistry (TEC) represents a direct and efficient method for the introduction of amine group into vegetable oil. The reaction can be performed in air without the complication of competing side reactions with oxygen.
http://hal.archives-ouvertes.fr/docs/00 ... POLSCI.pdfUV-Curable, Seed Oil-Based Coatings by Cationic Photopolymerization: Part 2Linseed oil
http://radtechreport.org/RT-Reports/sep ... rt%202.pdfPlant oil-based uv-curable coating US 20120202909acrylated plant oil such as acrylated epoxidized soybean oil.
https://www.google.com/patents/US201202 ... CDUQ6AEwAADEVELOPMENT OF NOVEL BIO-BASED POLYOLS AND THEIR DERIVATIVES FOR LOW VOC COATINGS APPLICATIONSEastern Michigan University
http://www.reeis.usda.gov/web/crisproje ... tions.htmlSYNTHESIS AND CHARACTERIZATION OF ACRYLATED EPOXIDIZED SOYBEAN OIL FOR UV CURED COATINGS Acrylated Epoxy Soybean Oil, January 28, 2011
http://ena.lp.edu.ua:8080/bitstream/ntb/11180/1/13.pdfHighly Functional Acrylated Biobased Resin System for UV-Curable Coatings2011
http://radtechreport.org/RT-Reports/spr ... atings.pdfAn outline of UV resins:http://www.esf.edu/outreach/uvebwebinar ... 12_MJI.pdf Soy-based Polymer Building Blocks: - A Sustainable Platform for Advanced CoatingEastern Michigan University
http://www.michigan.gov/documents/deq/d ... 3196_7.pdf
Posted: Fri May 09, 2014 9:41 am
Good references!
I was just at 3D/DC the other day, and I met some fellow students of AndersonTA who have created organic-compatible UV resins. I may have to ask him to chime in on this.
Posted: Fri May 09, 2014 2:39 pm
by sgraber
Currently the bulk of the products on the market are non-vegetable-based formulations. That said, "green" chemistry would be nice, but it'll also come at a cost. Are you willing to pay a premium for a vegetable/bio-based formulation?
Posted: Fri May 09, 2014 6:06 pm
by seasicksinbad
I just bought a pound of clear epoxy form smooth-on and ordered a sample of a cationic photoinitiator to start experimenting.
I also ordered Sun Cure Ultra Violet Catalyst UVC 2000, which I plan on mixing with polyester resin ( fiberglass resin ) and the clear epoxy. Epoxy and Polyester tend do be hard and brittle so I might need to put an additive to make them somewhat flexible.
Pigments to prevent light from bleeding.
I'll keep you posted on the results.
Posted: Thu May 15, 2014 7:04 pm
by @A2
Posted: Fri May 16, 2014 9:56 am
by @A2
Resin recipeshttp://tjsnyman.com/tjsnymanblogspot/?page_id=531CYTECRADCURE ENERGY CURABLE RESINS From cytec these guys are great and helpfull. And dilutants TMPTA for ADDITOL and EBECRYLS…EBECRYL UV-curable resins and oligomers
UCECOAT waterborne UV-curable resins
ADDITOL photoinitiators and additives
RAYLOK UV-curable resins
UVEKOL Glass laminating system
http://www.cytec.com/businesses/additive-technologiesSigma Aldrich1) 98 ml Poly(ethylene glycol) diacrylate CAS 26570-48-9 Sigma Aldrich # 437441
2) 2 grams of Phenylbis (2,4,6-trimethylbenzoyl)phosphine oxide (Irgacure 819) CAS 162881-26-7 Sigma Aldrich #511447
3) 0.02 grams of Sudan 1(one) (also known as …1-Phenylazo-2-naphthol…) CAS 842-07-9 Sigma Aldrich # 103624…thats it for recipe 1
http://www.sigmaaldrich.com/united-states.htmlPhotoinitiators for UV curinghttp://people.rit.edu/deeemc/courses/03 ... curing.pdfI have to use a wax in a carrier monomer type liquid to form the chain bonds. known as
TRPGDA (Tripropylene glycol diacrylate) from SHAMROCK TECHNOLOGIES inc. in their “everglide range of products” UV-691 , UV-636 , UV-600D , UV-395D
Fluoropolymers and Waxeshttp://www.shamrocktechnologies.com/pdf ... atings.pdfHow to mix UV resin, Recipes:
http://reaktor23.org/de/projects/3dprinterThree-Dimensional Printing Using a PhotoinitiatedPolymerhttp://reaktor23.org/_media/de/thinktan ... olymer.pdf
Posted: Fri Oct 03, 2014 12:04 pm
by Colby
Hi I'm new on this forum but found a great deal of interesting info on third-party resin for SLA printers. I'm particularly interested in the bio-based resin that would be compatible with the new SLA printers out there.
@A2 do you know if anybody is pursuing this idea, whether it is based on the paper you mentioned or on other sources?
Posted: Tue Jan 27, 2015 1:58 am
by benty
Hi A2,For a UV-curable resin to be suitable for 3D printing i guess the critical property must be how photosensitive it is, to maximize print speed. I'm a chemist by profession but i haven't any experience with polymer chemistry, and i think i'd like to read up on the subject. What mechanism(s) cause a material to photopolymerise, and how would one optimize this behaviour? I've read some very interesting hints about what might be done, like cooking a UV-resin from linseed oil (Green Chem, 2011, 13, 1014 DOI: 10.1039/c1gc15038c). With a bit of research, it sounds to me like it would be possible to make your own resin from mostly renewable, dirt-cheap or even self-produced precursors. I also read somewhere about someone who built a kayak with epoxy resin synthesized from, i think it was, linseed oil, but i can't find any details on this. Epoxy is a bit pricey, it'd be awsum to be able to DIY in my opinion. Anyone else here thinking in these patterns? Is there any opensource development being done in this area? I am waiting for your hopeful reply..Keep in touch with us..Thanks in Advance
Posted: Mon Mar 30, 2015 11:39 am
by DocMaster
Ember's Resin is Now Open-Source!!
Autodesk Standard Clear Prototyping Resin for Ember (all percentages are wt/wt)
Oligomer: Allnex Ebecryl 8210 39.776%, Sartomer SR 494 39.776%
Photoinitiator: Esstech TPO+ (2,4,6-Trimethylbenzoyl-diphenyl-phosphineoxide) 0.400%
Reactive diluent: Rahn Genomer 1122 19.888%
UV blocker: Mayzo OB+ (2,2’-(2,5-thiophenediyl)bis(5-tert-butylbenzoxazole)) 0.160 %
Source:
