i´m really curious about the time i need to expose a 100µm layer of SubG+ when using the Acer H6510BD. It takes at least 10s to cure such a layer, even at full power mode. Is it depending so much on the resin as i have read that FunToDo resin needs roughly 1-1.5s to cure the same layer?
If i´m exposing a 100µm layer by only ~5s, the surface is somekind of waxy, even after curing it several hours in an uv-light oven.
Your input is highly appreciated
