Hi all,
Can anyone describe the relation between the wavelength and the resin?
How could we measure the wavelength of the projector and the required wavelength for the resin?
How could we modify the wavelength of the projector?
I have 2 projectors, each one acts differently with different materials. I'm really confused.
Wavelength and resin
pouryatorabi
- Joined: Sat Feb 14, 2015 1:00 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
mongerdesigns
- Joined: Fri Nov 14, 2014 4:07 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Wavelength and resin
The two different projectors acting differently could be because of the color wheel.
pouryatorabi
What's the problem with color wheel?
actually I have a vivitek and an acer, the vivitek makes the parts thicker than the acer. I tested the vivitek without the color wheel but had no success.
