I just wanted to share my experience with making a flexvat. After seeing lots of great designs in this forums I decided to give it a shot myself. After failing with a acrylic version (Too thin material to withstand the forces) I decided to make one out of aluminum. And since I don't have a CNC router I decided to build it out of seperate alumium profiles and put it together with screws. That meant cutting a lot of threads, but now it's stable as hell
FlexVat, Aluminium
Matze
FlexVat, Aluminium
The outer dimensions are 30x18cm with an inner build size of 20x12cm. The bottom part is made out of a HPL plate because I thought a little bit more flexibility was needed. For now I'm using 0.05mm PTFE film that allows and accuracy of 0.5mm details since it's not clear, but a bit blurry. Still waiting for the FEP-film delivery... Any comments and thoughts are very welcome:
Hugues
Re: FlexVat, Aluminium
Thanks for sharing !
I was planning to build mine using my FDM 3D Printer. You say acrylic was not strong enough ?
Matze
I was using 4mm acrylic. And that didn't go too well. It was ok for a couple of prints, but after changing the film a couple of times (testing different materials) the acrylic started to crack and it "felt" that is could hold the tention. But maybe that was an design error... I think for future builds I'll invest in some CNC routed/laser cut aluminium parts.
seasicksinbad
Very nice!! And a good size as well. I made mine out of aluminum and was having a hard time putting the pieces together only with the help of bolts. Until I found out you can actually solder/braze aluminum with Alumiweld rods.
They are very easy to use, inexpensive, and you only need a torch and some practice. Here in the U.S. you can find them at Harbor Freight (cheap) and Home Depot (expensive). There's a bunch of videos on Youtube on how to use them.
Matze
Thanks for the hint. I didn't know that. Looks fun
