Acer P1500 settings?
DanOrgan
Re: Acer P1500 settings?
Thx, Sodium. I'll experiment with mask creation when I get my UV sensor. If I'll fail, it is possiable to create mask from photo.
lab
- Joined: Sun Mar 08, 2015 1:39 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi all,
I have the same problems with uneven light distribution (ACER 6510).
Anything new on that? Does Creation Workshop support gray masks?
DanOrgan
Lab, I had created the gray mask. You can find instructions from nc42 , but I used another type UV-sensor, my own code and 3ds Max.
Without mask, light distribution deviation was from 35 to 80 points (whole range: 0..255). With not-so-good mask it drops to 35-45 points.
But I printed only one model with my mask. For some reason, I can't properly load mask file now. Maybe problems with file permissions in Windows, or a bug in CW.
But I think, generally, that grey mask is able to solve uneven light issue.
