[HELP]More informaion please...
- Joined: Wed Jun 17, 2015 6:14 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: More informaion please...
OK, thx
I am using 15 mm spacers at first front position for my Acer P1500. But you must check it yourself, by placing buildplate and paper on the vat.
OK, I do it, thx.
Re: [HELP]More informaion please...
Hi !
First print first, failure. The print did not stick properly to the plate (he floated in the vat), I thought I had sanded enough aluminum plate, so I sanded it more.
- In "Creationworkshop" the first layer is not full, how to solve the problem ?
- The build plate must be flush the top of resin or VAT ? (VAT I think).
- To load the resin the vat, can I work with indirect light ? Or should I work in the dark ?
Thx. I think I do not desactivat the Acer screen saver ^^.
Ok, thank you very much, but I dont understand for build-plate positioning...
When you are filling resin in the VAT (petry dish), the build platform must be somewhere up. But when you start printing, it must be at the lowest possible position.
Do you watch tutorial? It is very helpful.
Ok, thx. Yes I seen it but my english is verry poor...
Fail again but he stick to the build plate.
Increasing the cure time should help. I think you are losing the print when the base layer transitions to the normal layer time, so you would want to increase your normal layer time.
