z axis calibration
faffer
z axis calibration
Postby faffer » Thu Oct 09, 2014 10:02 pm
Hi Steve, My first print turned out just great using your software. I've run into a bit of a problem on the z axis calibration. I've attached some pictures. There seems to be a drift as the z axis distance increases, is there a way to do fine adjustments? or is this a firmware problem? I'm using the Uncia
Archive.zip
(900.55 KiB) Downloaded 1428 times
Re: z axis calibration
Postby PacManFan » Fri Oct 10, 2014 11:40 am
Can you determine how much it's off by?
Start at a position, and move the z axis 100mm using the software. Measure it and let me know how much it's off by.
faffer
Postby faffer » Fri Oct 10, 2014 8:21 pm
off by 3mm for 100 mm travel
Postby PacManFan » Sat Oct 11, 2014 12:44 am
faffer
Postby faffer » Sat Oct 11, 2014 6:22 am
I did an accurate measurement today 102.8 mm
faffer
Postby faffer » Sat Oct 11, 2014 8:22 am
Brandon Pomeroy picked up my thread on this issue and did a mod on CW .I get 99.60 :)
attaching his file
dangre
Postby dangre » Sun Nov 09, 2014 9:14 am
Did this ever get resolved? If so what was the solution?
PomeroyB
Postby PomeroyB » Mon Nov 10, 2014 6:22 am
dangre, the problem was that CWS approximates the Uncia's steps per mm to be 90, when the actual value is closer to 87. I posted a recompiled version of CWS that had the correct value on the Uncia Google Group.
