Blue and purple tend to have the worst light bleeding (So I've heard). I'd give red or yellow a try (With the same settings as you currently have) to test that! Good luck!
Getting closer to first print, Z axis issue...
Re: Getting closer to first print, Z axis issue...
You may also have an issue with light bleeding -- it causes your edges to be fuzzy, since the UV is refracting a further distance throughout your resin.
mhackney
- Joined: Sun Feb 15, 2015 9:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks! Yes, I was considering trying red or yellow as I hear they are easier to print. Then I'll have some data to compare.
Michael
Michael
