Uploaded this to DB for anyone that is wanting to use Marlin on there DLP build with CW. It is setup to use a hobby servo off of pin D11
You will need to change the max travel limits after homing to fit your build, this uses one end stop for the Z and software limited for the height.
End stops will also have to be configured depending on which type your using, this build is setup for hall effect end stops.
Clinton
Working Marlin Firmware
Nica
- Location: Pretoria South Africa [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Working Marlin Firmware
Hi i also tri to load my new dlp projector software what i have built in same concept. I tri to download your file for marlin but forum says it has been removed. Please help
dalaura10
- Joined: Mon Nov 10, 2014 1:26 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I have the same problem, must set up firmaware Marlin for the CW.
I can not find where seting the pins step and direction in firmaware.
If anyone can help thanks.
- cncbasher
all settings are in configuration.h
this also depends on what breakout board your using such as ramps or sanguino etc
gold782
- Joined: Mon Feb 23, 2015 2:51 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
anyone can help me to have malin firmware so that I can use it for my dlp type printer.
I have z axis and ramps 1.4 and arduino mega 2650. tilting only z axis.
I want to have servo shutter for the printer.
i have try to look for the drop box and it say gone...
sloxd
- Joined: Sun Mar 08, 2015 4:25 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Or if anyone else could upload configured Merlin/Sprinter firmware which works with CW? Thank you in advance.
sodium
uploaded mine. is working with 5 mm pitch screw, 1/16 microstepping, 1.8º stepper, endstops activated, servo activated, 200 mm z travel, ramps 1.4 and lcd activated also.
good luck !
i dont take responsability if your house burns or falls apart
good luck !
sloxd
Thank a lot
RICHA PATIL
- Joined: Wed Sep 09, 2015 4:47 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
can anyone post the configuration file of a working marlin firmware for DLP 3D printer. i m struggling a lot. unable to do changes. help me.
