must see ifno needed
Posted: Thu Jun 18, 2015 10:14 am
ok so here the dealio
build my top down and all working with a small odd problem..ok I put the projector on top and made a cube 10mm x 10mm x 10mm moved the build plate till cube from projector was aproxx 10 x 10 mm so did a test print and.......sweet came out 10 x 10 x 15.7 ...so when online used the http://prusaprinters.org/calculator/ and got..2560.00 Click to Share! 1.25 1.8° 1/16th 1 : 1 so I put 2560 in sprinter instead of the 3200 that was there...did another print and cool 10 x 10 x14.2 ok now getting lost?....so I marked the 8mm smooth shaft on my z axis and in cw moved it down 10mm checked at it was 13.36 not the 10mm..........I have no CLUE HERE
heres my set up ramps 1.4 arduino 2560 nema 17 8mm lead screw from purisa i3......
