Hi everyone,
I have problem running the creation workshop, Whatever I did, When I clicked on the creation workshop icon, it gave me an error, so I changed my windows and tried it again, this time nothing happened, not even an error. What should I do?
Creation Workshop won't run
pouryatorabi
- Joined: Sat Feb 14, 2015 1:00 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Creation Workshop won't run
What did the initial error say? Do you remember? What version of windows do you have installed. Do you have anti-virus software installed? When you say, "Nothing happened" what do you mean by that? What icon are you clicking on? Are you talking about the Creation Workshop desktop icon?
newraper1963
- Joined: Mon Jan 19, 2015 6:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
CW never has worked for me from the icon. I have Windozs 7 on my laptop that i use to run my printer. I have to go into the original CW file and load it through the execute file. Works fine that way for me. I wish I could easily run it on my Ubutu Linux machine like I do my fdm printer.
pouryatorabi
I'm using windows 7 and I can't remember the error, I know what icon to click because I've tried it on my friend's laptop and it worked, when I say nothing happens really nothing happens, not even an error. I thought may be there is a setup file I should use, any help?
pouryatorabi
It seems no one can help me and I'm helpless.
Does the software need any files like .net framework or something else ?
nc42
Are you clicking on an icon on the desktop or in the CW folder?
pouryatorabi
actually I ran the software with one of my friend's laptop, it ran without any problem, I did the same process on my own but nothing happens, as if I've just right clicked and clicked on refresh button.
dangre
Have you tried to uninstall/reinstall? Sounds like a bad install.
pouryatorabi
There is no install/uninstall option for creation workshop. If you mean deleting and unzipping, Yes I've done.
