Tons of new features for you!
It's been a while since I posted an 'official' build. Version 36 is very stable.
Light correction masks are now supported as well.
Please post any relevant feedback to this thread. Next version should have a bunch of pre-configured machines.
Creation Workshop 36
MrBaz
- Joined: Sun Oct 12, 2014 9:55 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Creation Workshop 36
Looking good. Slices faster than previous versions.
AndersonTa
adambx
If I export SVG, does that mean that there is no need for antialiasing anymore since vector display is usually antialiased already?
Cheers
Cheers
asillybird
- Joined: Sat Nov 08, 2014 8:57 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- cncbasher
sillybird: what problems errors do you have ?
- cncbasher
is the source for the laser plugin going to be available ?
AndersonTa
I'm also noticing much longer slicing times, is this supposed to be the case? Something that used to take a few secs takes 5+min to slice now.
@AndersonHTa
