Hello;
Paid version I am in for it;
8 inch tablet and CW
Re: 8 inch tablet and CW
Hi Pandapp,
just wondering about your Acer, how did you solve the power supply poroblem to the acer?
it also uses the usb port to charge the tablet correct?
here we don't have a split usb cable where on on side.. you can charge the tablet.. and the other side.. can connect to the arduino
peerless
- Joined: Fri Dec 26, 2014 10:37 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hello,
I am very interested in this, is there any updates on these project??
peerless
So I am running CW on a ACER W4 but still have to do the actual slicing on a laptop. I am assuming this is a system resource issue on the tablet??
@pacmanfan - do you foresee cw being able to slice on a small tablet pc in the near future?
peerless
Trying to save the images:
Should I not enable this option?
peerless
I am trying to run my new Titan 1 and we have to take your images, then zip them up, then use their software to run the parts. Its kinda clunky process. Their software is ok but its so many steps....
I would rather just try and run straight from CW, do you know how big of deal this might be? They used reprap/grbl style controller....see image.
- PomeroyB
Peerless, you should be able to flash a normal RepRap gcode like Marlin to your Arduino, and just go straight from there... but you need to know things like the steps per mm for your motor/leadscrew combination.
