Hi Steve.
I've been playing with parameters for the resin test. But do not understand how it works.
Can you explain the correct method?
Test Resin Dialog Box
firecardenal
Re: Test Resin Dialog Box
It allows you to test multiple exposure settings in a single print. You'll enter the base time in the minimum exposure time box. There are 10 steps/boxes, each step adds the 'exposure step'. This allows you to start with a small time, and work up to a much larger time. After the print is complete, you can examine the model and determine from the boxes which exposure works best for your resin.
firecardenal
Ok, Steve.
I will try to aply.
Thanks again
I will try to aply.
Thanks again
JSmith172
- Joined: Mon Feb 02, 2015 2:19 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
woukd it be bettr for each step to have their own square?
how_eee
+1
that way will be much closer to real print.
seblos
what kind of press I use?
Sebastiano
Sebastiano
