What is the status of Creation Workshop for Mac? Last I heard it was being worked on, is that still true? When will it work?
Thanks,
Michael
Progress on Mac version of Creation Workshop {UPDATES!?}
MichaelD33
- Joined: Mon Aug 18, 2014 12:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
ecurtz
- Joined: Thu Aug 14, 2014 8:32 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Progress on Mac version of Creation Workshop
I've played with it a tiny bit, and there are bugs in OpenTK that mean it's currently unusable. I'd obviously like to be able to use it, so I'll keep working with the code as I have time, but that's certainly not a commitment to make it work, and I have no idea what PacManFan's longterm plans are for the Mac version. Any other programmers interested on OS X should certainly get the code themselves and take a look at it.
I think it may be as simple as rolling back to a previous version of OpenTK. I remember the prior versions seemed to work alright.
MichaelD33
ecurtz
You can build Creation Workshop from the github source without much hassle using Xamarin Studio: http://xamarin.com/download
Previous releases of OpenTk are available here: http://www.opentk.com/node/508/release
MichaelD33
MichaelD33
Can someone please give me an update on this??
mattberg
- Joined: Mon Oct 13, 2014 3:10 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Progress on Mac version of Creation Workshop {UPDATES!?}
Have you tried parallel bootcamp? I'm running it on my macbook pro and it seems to be running CW pretty well...
Kvirre
I second that .... I would like to use my Macbook Pro for this.
Bootcamp is possible but ....
wkarraker
- Joined: Fri Jan 30, 2015 4:25 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Curious if anyone has had luck building the latest version of CW with rolled back libraries. I'm contemplating converting my mUVe printer from laser to DLP, they mention CW as being the best solution.
