Build Your Own SLA/SLS • Creation Workshop for MiiCraft
Posted: Tue Oct 28, 2014 1:17 am
Latest version CW:
with machine / slice profiles for MiiCraft printer.
Highly experimental, if you have a MiiCraft please post and help test.
Re: Creation Workshop for MiiCraft
Posted: Thu Jan 22, 2015 11:22 am
by herman1234
How can I setup output resolution for MiiCraft?
I like to try new CW but failed
Posted: Sat Feb 21, 2015 10:48 am
by imret
Hi
I'm new for both Miicraft and Creation Workshop.
tried it on Miicraft and got some problem.
1. resolution of Miicraft is 864*480(detected) but the actual printing area is 768*480. Also the slicing pictures should be 768*480.
2. didn't form the base.
3. pause and stop bottoms didn't work.
Posted: Fri Feb 27, 2015 5:43 am
by herman1234
It only works on version 13 to setup the resolution manually.
If you find any new version can work, please tell me to try it.
For the base, you should do by drawing tools; like MS paint, to replace the several layers on the first slicing layers.
To use MiiCraft, you need a inx file to let MiiCraft know the slicing picture numbers.
