Feature Request : Double Lift Movement Settings
Posted: Thu Nov 13, 2014 4:48 am
If you are using a flex-vat as I am, you probably noticed that you need several mm (5-10 mm) of lift to separate the part from the FEP-film.
But this is only true for the first layers (10) where I use a longer exposure-time, to get a good binding to the platform, and I need extra distance in the lift.
However, I don't need the extra distance for the remaining layers, since the lower exposure-times gives me a easy peel (and I don't need the extra lift-distance).
So what I would like to see is 2 different lift-distance-settings.
- One for the first layers (Increased Exposure, Increased Lift-distance)
- One for the remaining layers (Lower Exposure-Time, Shorter Lift-distance)
This would save me ALLOT of time during a print.
Please consider this extra lift-distance-setting, accompanied with the first layers exposure-time-setting.
