I have a suggestion for the bottom layers. With my flexvat (20x12cm) it would come in handy if there was a possibility not only to adjust the exposure time for the first couple of layers, but also the z lift distance.
A few more mm for the bottom layers would give the resin more time to flow back, specially with larger bottom layers. Or does this feature already exist?
Thanks and best regards,
Matthias
Suggestion, Bottom Layers
r255
- Joined: Tue Jan 27, 2015 6:22 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Suggestion, Bottom Layers
Hey Matze,
Take a look at the gcode view
If i am right this is the code that is responsible
;<Slice> 0 =[ slice number ]
;<Delay> 5000 =[Layer Exposure time]
;<Slice> Blank =[ dont know ]
G1 Z5.0 F50.0 = ( G1 Z[z-lift distance] F[z-lift speed] )
G1 Z-4.9 F100.0 = ( G1 Z-[z-lift retract distance] F[z-lift retract speed] )
;********** Pre-Slice Start ********
;Set up any GCode here to be executed before a lift
;********** Pre-Slice End **********
The z5.0 and minus z-4.9 fit the 0.1 slice size i have setup.
Hope that helps
PS: Guess you have to skip the next layer if you change the layer size from 0.05 to 0.1 to keep size consistent.
Hope that helps
Matze
@r255: Thanks, I'd guess I'll have to have a deeper look on g code
@PacManFan: Awesome!
