im not sure, but it seems the variable H just indicate the home position, in this case 0. it not send any command to execute, like g1, g28, etc ... anyway, had you tried send the command via manual gcode window¿?
i think is better to adjust z0 before press play button.
GRBL Homing ($H) problem
CihanAlak
- Joined: Wed May 06, 2015 6:27 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: GRBL Homing ($H) problem
When i send $h via manual code it goes limit switch and zeroing coordinate then start process.
sodium
;********** Header Start ********
;Here you can set any G or M-Code which should be executed BEFORE the build process
i think its self-explanatory
CihanAlak
I know i read that.
I write $H ;Go home and zero Z axis but
After slice, at g-code view .0 ;Go home and zero Z axis
Why "$H" turn to ".0" it is basic question and problem?
PacManFan what do you think about it?
CihanAlak
Really thank you i wll try that.
Best Regards
Cihan
Best Regards
Cihan
